-   Solid State CRT Televisions (http://www.videokarma.org/forumdisplay.php?f=184)
-   -   When did the switch from "wide" to "tall" CRTs occur? (http://www.videokarma.org/showthread.php?t=270524)
ESigma25 06-04-2018 08:19 PM
So we all know that CRTs, even non-console sets, used to be in a "wide" form factor with the knobs/buttons to one side of the tube and speakers on either side of the tube. And that by the mid 90s all non-console sets had changed to a "tall" form factor, with the speakers and buttons under the tube. My question is...when did this change start happening? My old 1990 Sanyo set was a "tall" set but in 1989 there were definitely still "wide" sets.
maxhifi 06-04-2018 08:53 PM
Mid 80s as far as I remember.
Electronic M 06-04-2018 11:15 PM
Really it was more of a shifting design trends thing. If you go back to the dawn of consumer TV in the late 40's both styles and some others we have not seen made since were played with, and both pretty much coexisted all along with the relative popularity varying all the time...It started becoming more of a monoculture in the 90's because most of the sets were Asian made, and cheap commodities by then...Once a product hits that point stylistic creativity/diversity tends to die.
dishdude 06-04-2018 11:56 PM
Mid 80's as mechanical tuners went away. By 1990 almost all had the control panel under the screen.
zeno 06-05-2018 09:06 AM
Its a style that came & went over the years. Some 50's
bug eyed Zeniths are narrow. Many early 60's were made
in the suitcase or attache style. "Top Tuning" sets were
also narrow. For color the mid 70's Sony 17" comes to mind
first. All controls on bottom & it looked real odd to us.
In the 80's it became the "cube" style. That spred like wild fire
since you can get a 25" into an area a little bigger than a typical
19-20" Enuf
73 Zeno:smoke:
maxhifi 06-05-2018 09:23 AM
I think the switch from mono to stereo, is what did it.
That second speaker made the TV a bit too wide, so made sense to put them under instead. Also, the switch away from knobs to a row of buttons meant the control panel could also be much more narrow, and the universal adaptation of remote controls made it less important.
Notice how it's usually mono TVs with the horizontal layout, and stereo with the speakers under the screen. Later mono TVs did use the vertical layout, but they were usually economy versions of stereo sets, with some parts removed.
ESigma25 06-05-2018 04:15 PM
That's true, aside from console sets I've never seen a horizontal layout stereo set.
dishdude 06-05-2018 05:39 PM
There were a few, especially in the mid 80's. I really like the style of them.
user181 06-05-2018 07:18 PM
I have two Sony sets that are exactly this way. I suspect there are many other Sony models like this as well.
ESigma25 06-05-2018 07:54 PM
I definitely wish I could find the Sony and Mitsubishi high end stuff but sadly all I ever seem to find are 80s mono sets and low end stuff from the BPC era!
user181 06-05-2018 08:04 PM
Hang in there, and keep an eye out!
zeno 06-06-2018 06:32 AM
The sets are out there you just gotta dig for them. Go to yard sales
ESPECIALLY old folks, old neighborhoods & farms. ASK ! They are
often stuck in cellars, attics & garages. Only pay little or nothing for
them unless you know its a money set.
The hard thing is finding Sonys with a good CRT. You will find lots of
Zeniths & they were top of line sets. Almost always need little work &
are the easiest to fix. Just remember almost all old sets are worth
NOTHING. In fact I wish someone took my old 36" Sony XBR for free !
73 Zeno:smoke:
WISCOJIM 06-06-2018 10:10 AM
Interested in one of these (with matching stand)?
Sony KV-3000R
https://i.ebayimg.com/images/i/11156...-1/s-l1000.jpg
ESigma25 06-06-2018 02:11 PM
No way, I don't have anywhere near enough space for that! Right now I only buy/pick up sets that are 21 inches or less...
maxhifi 06-06-2018 02:25 PM
Sony KV-3000R
That's one heck of a TV!
