-   Diagnostic & Test Equipment (http://www.videokarma.org/forumdisplay.php?f=177)
-   -   Precise Model 111 tester (http://www.videokarma.org/showthread.php?t=271666)
Stlouisian 05-19-2019 12:46 PM
Does anyone have the wiring diagram for the adapter that allows you to test the Compactron, Novar and a few others tubes on a Precise 111 tube tester? It uses two Octal males to plug into the tube tester. One used is the Octal with the tester and the other plugs into the unused socket in the middle. The middle one requires putting in another octal socket. Trying to find out how to use this adapter and configure how to wire the new socket in the the tester too. Thanks for any help.
Stlouisian
[email protected]
