Sony Trinitron kv-1201 issue
This tv worked fine for a while and then one day it just stopped. Now it only shows this line. I replaced a bad capacitor but it still does this. Any Ideas?
https://i.imgur.com/HmAUCQC.jpg |
You have lost horz deflection. It is almost always a bad cap in series
with horz winding of the yoke. Its a special non polarized electrolytic & a wrong sub will quickly fail. If you order a manual there are at least 2 versions of this set. You need model, chassis & serial numbers to get the right one. 73 Zeno:smoke: LFOD ! |
John |
Check all connections and solder joints. If that sounds like a pain, it is. But good chance it's simply a loose connection.
You can always try the caveman method. |
Could also be a broken wire or bad connection to the horizontal coils of the yoke. The KV-1201 didn't have the SG613's the blew. Those came along about '74 '75 models.
| All times are GMT -5. The time now is 07:25 PM. |
