Couple Zenith Avante Questions
Have a couple questions about appearance and strength.
Does anyone know what the white paint used on the cabinet is and what shade of white? So many chips and dings. I want to first touch it up, then one day take it apart and refinish it. Will also paint the base along with it since doing retrobright only 6 months before it started turning yellow again and in another year it was back to what it was before. How strong is the top? I have an RCA VDT-350 I would like to put on top, but not sure what that might do in the long run. It seemed to handle it well when I placed it on top, but didn't leave it because I was afraid it might not hold up well over time. I would say the VCR is over 40, but under 60 lbs. Thanks |
Dont worry about the weight of the VCR. You could probably stand
on it IF you dont jump up & down. Things were built different then. I remember walking on the hood, trunk & roof of my '72 Olds Toronado. Four of us sat on the roof for a good view of the fire works. No damage, just made a popping sound when we got off. Try some rubbing compound in a corner somewhere see if it helps. IIRC there were other threads on the Avanti cabinets also. 73 Zeno:smoke: LFOD ! |
I've sat on my Avanti...it has had an 80Lb Stromberg Carlson TV-10 (Dumont RA-103 with a different cabinet) sitting on it for years now.
Perhaps you could take a paint chip to a paint store and get it matched. |
Is it actual paint ? If so look under the base & if its finished there you
can grab a big chunk. Nobody will ever see it. Other smaller sets of that era used white but the color was in the plastic ( example E4030X ). So the compound idea..... Dont remember the Avanti but the white was very pure & the low end of semi gloss. 73 Zeno:smoke: LFOD ! Quote:
I could just pick a shade of white with low gloss as most wouldn't know or remember the true shade used. |
If you need a paint chip bigger than your comfortable obtaining to match instead just grab a bunch of color sample swatches hold them up to it and pick the closest one you find...Most sets have faded a bit anyway so if you repaint it a close but slightly different shade it won't be easy tell....
IIRC the back of mine is painted the same color...you could probably bring the back in as your paint chip and just have them be gentle with it... |
| All times are GMT -5. The time now is 07:24 AM. |
