-   -   help me ID this mystery GE roundy plz! (http://www.videokarma.org/showthread.php?t=273251)
Yamamaya42 09-15-2020 04:11 PM
https://imgur.com/WvpxRTp
i know these px suck but I found this locally and I'm tempted to get it, but can find NOTHING about it, even with the MO# info from the back :o
https://imgur.com/HovvPWO
https://imgur.com/k54TvR3
https://imgur.com/wXwRzpB
what is it, who REALLY made it?
Philco? RCA?
if I cant find service info on it, it's just parts, I'd rater restore it.
any help welcome!
thanks!
old_tv_nut 09-15-2020 05:51 PM
SAMS lists a GE M939ACD:
https://www.samswebsite.com/en/photo...earch&s=Search
SpaceAge 09-15-2020 06:00 PM
The back cover and front control layout resemble this GE in a Shango066 video, which he identified as a CTC-15 clone.
https://m.youtube.com/watch?v=kTesct_7uOA
Yamamaya42 09-15-2020 06:56 PM
thanks! I guess I was looking up the MO# in sections, not as a whole :/
that's why I got nothing :(
reeferman 09-15-2020 09:49 PM
I have the Photofact in PDF if needed.
dieseljeep 09-16-2020 09:32 AM
If you miss it, you're not missing much.
That thing's a dog. I scrapped one. The only good thing about it was the RCA 21FBP22 HI Lite CRT which was perfect!
The CRT was used in a much more deserving set, a Zenith 23NC**. The last roundie Zenith made.
The set isn't an RCA clone, a lot different.
Electronic M 09-16-2020 11:16 AM
Personally if I had more space I'd be interested in picking that set up... from what I understand they were sort of like a portacolor with a transformer power supply and traditional roundy sweep circuits.
The worst limiting factor of picture quality in the portacolor was the coarse dot pitch CRT...the roundys didn't have that limitation... There's a LOT LESS GE roundys surviving than RCA or Zenith so IMO they are worth preserving more than the RCA designed off brand clones.
The premium sets are nice to collect, but you can't fully appreciate a Dumont till you've experienced a Muntz.
Yamamaya42 09-16-2020 11:38 AM
Well, it's about 50 miles away from me, much closer than the stromberg carlson x-21 was, so I guess it's worth a try!
Tom9589 09-16-2020 07:44 PM
The GE Portacolors had two different CRTs: 11SP22 and the 11WP22. The early 11SP22 had the coarse dot pitch and the later 11WP22 had a much finer dot pitch - a much better picture. I owned one of each.
dieseljeep 09-17-2020 11:18 AM
Actually, the GE KC and KD chassis is a glorified Portacolor!
The AC chassis set is a bit different using 6AU8's in the color circuit.
It's worth looking the schematic! IIRC, they made a rectangular set with a similar chassis.
Tom9589 09-17-2020 01:27 PM
Electronic M, your comment about not fully appreciating a DuMont until you have experienced a Muntz reminds me of my first high school job in a garage. A 1959 Rambler came in and I got the job to fix it. I groused a little bit about doing it and one of the other mechanics said I couldn't appreciate working on a Lincoln until I worked on a few Ramblers! He was right.
DavGoodlin 09-17-2020 02:04 PM
The CA chassis had a CTC15 clone look to it in many ways but GE revised some most circuits to use their tubes. i.e. 6BH11, 6FM7 etc.
I saw one of the CA or CB sets on an episode of "Mister Ed" when Wilbur brought home
a color TV one day, in an Italian Provincial IIRC.
Tim Tress 09-19-2020 08:29 AM
I trained on a CX chassis, almost 50 years ago. It was RCA made, and seemed to be close to the CTC-12, with a few elements of the CTC-15. I think that was the last RCA chassis that they used.
Yamamaya42 09-19-2020 12:09 PM
well, I'm close to having it in my paws!
Yamamaya42 09-19-2020 10:23 PM
It's mine!
:banana:
https://imgur.com/6uhmLi7
very bad cataract
https://i.imgur.com/VuWhH0y.jpg
https://imgur.com/vSwF40g
https://imgur.com/Yty9iP5
reg cap is loose fitting, falls off easily.
https://imgur.com/N9dESJM
https://imgur.com/b1TBULo
https://imgur.com/rQgBKXh
now that is VERY stupid...
rather than replacing a bad socket, someone soldered the wire to the focus pin of the CRT? WTF? :thumbsdn:
https://imgur.com/58xIKOB
blue is a bit low, but the CRT is not dead, not as strong as the one in my CTC-16xl, but could be worse.
gonna let it sit a bit and wake up
