Rca ctc145e
5 Attachment(s)
Hi All,
I found this 13" RCA ColorTrak TV and am considering keeping it. It is from 1989 and only has an RF input. Does this look like a hot-chassis tv? If so, is there a reasonable, inside-case way of making external connections safe using low amp fuses or isolators? |
Used modulators are available at thrift stores for a buck or two. |
Dittos, HOT chassis. You can assume ANY set without composite
inputs is hot from abt 1978 on. These were a good set, a real workhorse. But the value is ZERO or even negative $$ due to disposal fees. Plenty of sets with jacks out there still running, just ask around. Expect to get them free or a small token amount. 73 Zeno:smoke: LFOD ! |
Thanks, got the modulator and dug out the Atari. 8 bit graphics and RF haze take me back.
| All times are GMT -5. The time now is 03:07 PM. |
