1989 RCA Console Set
I am wondering if the CTC167CS Chassis used in RCA Sets were notorious for the Eeprom failure issue and also the issue with the Ground Solder Connections? I presume this particular Chassis does not have a separate tuner board assembly like the older RCA Sets?:scratch2:
Thanks. |
E-prom sets were CTC175, 176, 177, 186 & 187 IIRC
Older ones had separate tuners. They also got cold joints under the connectors but easy to do. Never had a bad E-prom on the older ones either. IIRC the CTC167 used an SCR in the power supply & a good set. IMHO the CTC169 was the best. It had a killer pix & I only junked one, got big lightning hit. They were a bit of a PIA to work on. That one used a fancy SMPS Lots of parts but I never had one commit seppuku on me. 73 Zeno:smoke: LFOD ! |
| All times are GMT -5. The time now is 11:09 AM. |
