I’m Back! Pilot TV37
Hi guys… asking you stand by once again for another all hands on deck. Got the infamous 3” Pilot TV37 on the bench. Of course the first question…anybody got a line on a fresh 3KP4? I think I’ll find some hen’s teeth before I come across one of them!
I did one earlier this year. I need to get a set of the ships wheel knobs, and add the CRT heater protection diode (been variacing it as a protection).
If yours is like mine you'll need to change about %90 of the resistors along with the caps to get good stable operation. |
Lucky you. I still want to get a Pilot.
I'm a joyful recapper but 5000pf 6000V caps in the HV circuit? Jeeze...it only makes 2.5K in the HV circuit for the CRT! IDK if I can even find something like that. These are waxies. Can I sub ceramic caps?
I just go on mouser and get Wima brand red rectangular film caps of that voltage and .0047uF/4700pF they work great in all the various brands of electrostatic sets I've tried them in including my TV-37, and they're the cheapest new cap I know of... Only downside is this leads are short so I have to solder extensions on... Besides that I can't complain. I keep a certain number of them in stock so I can buy and start on an electrostatic deflection set any day I feel like it. |
Also, I picked up a 1948 Motorola VT71 today. It's in beautiful condition...outside. IDK anything about the CRT or the functionality but I had to grab it. Busy winter coming!
1 Attachment(s)
The grid and cathode shouldn't have HV. The deflection plates should. I think I measured HV off the point where the focus divider string under chassis ties in to HV box output.
Got it. Thanks so much
1 Attachment(s)
Thanks Tom...replaced the HV caps and the electrolytics. Surprised as hell and that picture shows the tube at reduced current...I had a 150 watt bulb in the dim bulb setup. I wanted to go to straight 117 volts and start fiddling with controls but I walked away. I was tired and excited at the same time at 8pm after a long day. That's a bad place to start fiddling with a 75 year old piece of vintage electronics that just woke up after 50 years!
| All times are GMT -5. The time now is 03:27 AM. |
