-   -   B&W CRT Question (http://www.videokarma.org/showthread.php?t=276057)
Chris K 08-13-2023 04:10 PM
B&W CRT Question
Hi all. I have a 10BP4 with strong emissions down to 4 volts, no shorts but the cutoff is poor. How does a tube get this way, what is going on inside the tube that might create this condition, what kind of picture quality can I expect and is there anything that can be done to remedy it?
Thanks VKers!
Polaraligned 08-13-2023 06:48 PM
The cutoff test measures the effect of the control grid. If you have poor cutoff, the contrast may be poor. I would just try the CRT in the set and see how it performs. The tester may be lying.
Electronic M 08-13-2023 07:49 PM
I had a tube with absolutely no cutoff in a RCA set and it actually worked ok and looked fine.
