1988 Emerson 19" model ECR2100D dead
Set powered on as soon as I plugged in. Started up and showed digital channel display and screen lit up with the usual static. Ran for about 10 seconds and shut off on its own. I then unplugged it and heard a relay. Since then, nothing.
Maybe bad regulator.
I would try on variac maybe 90v in ch b+. I assume safety circuit shut it down |
I find good buys at fleamarkets at hamfests
I find one coming up in your state maybe more https://www.arrl.org/hamfests/search Sometimes on shopgoodwill.com you can find good deals. If its at your local hub U could pu locally save shipping |
Normally the regulator is at the mains wiring input, after fuse, diodes and big cap for filtering; then it follows to regulator. It drives an transformer or a inductor (if it is a SMPS; probably due to age of this TV). THe main regulator for sure will have a heatsink.
For testing it, is not advised to isolate them from load; most old SMPS explodes without load. |
Look for a 100 k ohm IIRC off the B+ adjust pot.
Would restart but randomly go HVSD. A $1 test ! Zeno:smoke: |
I was always afraid to put a solid state on variac as I was told it could damage the set. Also my variac is modern one I got off Amazon its not the best but it works.
| All times are GMT -5. The time now is 12:57 PM. |
