Spectrum, TCM and 4:3
I have a Spectrum cable box and until May 1, I was able to receive full-frame feed from TCM whenever they showed pre-widescreen movies. When the channel broadcasts older movies, they appear zoomed out. I actually called Spectrum, they even sent a replacement box. I tried all of the different settings, even pressed the "Aspect Ratio" button on my remote numerous times to no avail. I have the box hooked up via phono to the back of one of my VCRs and am watching the video on a CRT TV. Is there a way to bypass the aspect ratio via analog phono so I could actually view the video full frame once more on my VCR and CRT TV? Is there a box that I should purchase?
First off there is no such thing as a phono connector. The correct term is RCA connector as they were the ones that came up with it. If you're using a VCR then it's RCA connectors are composite video (yellow RCA connectors) and line level audio, as opposed to component analog video (R, G and B cables RCA connectors) and audio.
If you have already exhausted menu settings I've made a video where I outline 2 solutions I use. https://m.youtube.com/watch?v=hKjt3x4WtWU |
Do you have any other devices connected to the pay-TV box, specifically using its HDMI connector? If so, disconnect it, and maybe then reboot the box. Properly, the composite-video phono jack output should be a 4:3 signal, and the "zoom" setting of the aspect ratio control should give you what you want. Beside the aspect-ratio button, the box may have a separate menu item to choose 4:3 or 16:9 mode.
(I could not find the "bang head on wall" emoji.) |
| All times are GMT -5. The time now is 01:27 PM. |
