RadioShack 16-236 color tv
1 Attachment(s)
First tube TV acquisition of the decade, I picked up this 13" television for $15, mainly because it says Radio Shack on it, and has a very strong CRT. It was filthy and had a cracked cabinet. It is now clean and the cabinet has been glued together. It appears to have been made in Malaysia by either Hitachi or Sharp, at the end of 1985.
Looks like a sharp. Good find.
Zeno:smoke: |
Oops! CRT-solid state. Maybe. I'd check for open speaker first.
I was at an Illwill (Goodwill) drop off point and there was a 19" Linytron there. The guy saw me looking it over and begged me to take it. He said they were just going to trash it. I passed on it. |
Most dont mute. Some mute pix & snd but leave the OSD on.
Toshiba high end did. It needs a hoz sync pulse to turn on. Zeno:smoke: |
I take no offence, to them the CRT makes it a "tube" TV, in the same way that youngsters calling what we used to call "Albums" or "Records" the newfangled trendy term "Vinyls" don't bother me either. It's their world now, I'm all for lettin em name stuff as they see fit to...... (Remember, OUR parents weren't all that enamored with what we called stuff either) :thmbsp: |
Might have an issue with the sound then. The audio output stage is really weird on this set but should be easy enough to troubleshoot. Hopefully the issue isn't in the large multi function IC, or in the volume control
Lol I just realized I opened with calling it a tube TV. Well the T in CRT means tube, and that's what they seem to call them in advertisements these days. I guess I got swept up in the new way of talking... it is in the solid state forum though. I have plenty of tube chassis TVs too. One thing that has changed though is 10 or 15 years ago I'd have never been interested in a TV from the 80s, because they were still common, but now they just aren't. |
On the Sharp labeled sets the key pad was crap. Buttons broke & the
contact mat shredded up. Unhook it & try a remote first. Otherwise a decent set. I dont think the big jungle IC is bad. Zeno:smoke: |
That tv sure looks like a Sharp to me too.... Best way to be sure is to pop it open and look at the labeling on stuff... PCB & CRT were usually labeled.. I doubt that tv blanks sound when off channel, looks to old for that. Outside chance it's a Sanyo, Sampo, NEC, or Toshiba. Linytron's were excellent tv's with long lasting CRT's I have about 6 or 7 of various sizes. We have a 25" in the bedroom as a daily use set since about 1986 or 7. I don't know it they actually get this money, but just type in Linytron into ebay, or Craigs List - those sets always have a high price tag on them.... If you got a chance to get that one at the thrift store for little to no money, I would grab it - not long till they are gone all-together. I use to work at a Sharp satellite repair center on their under warranty stuff, they made good stuff back in the 80's.... Simulated Wood Cabinet years were the best of the transistor tv days.... . |
Yah, I forgot about Hitachi, better guess than NEC, I was thinking of something else. Hitachi did do a lot of products for other brands kinda like early Sanyo & Toshiba. Well, the keypad does look like my Sharp keypad layouts. Anyway you have a nice clean set with a good CRT, it's not like they grow on trees, one day they will be hard to find.... . |
Have had a chance to test it - sound works great, it does mute with no picture. One issue though, is no color. It's got a well converged and sharp monochrome picture but no color at all.
Has anyone got a Sams 2620-2 ? The Sharp 13MM17 seems to have the same color section as this TV (Based on IC X0212CE) , and any documentation would be very helpful in troubleshooting.
IC is probably a Toshiba TA7670 (P).Look for a data sheet.
A Sharp chassis about this vintage had a piston cap in the color that caused either no color or color bars, dont remember which one :sigh: Also be sure if it has any tuning mode switches they are in NORMAL for OTA TV. Will check for Sams Fri. Zeno:smoke: |
| All times are GMT -5. The time now is 01:15 AM. |
