-   -   90's color tv help (http://www.videokarma.org/showthread.php?t=3181)
ProAc_Fan 12-08-2002 02:09 PM
90's color tv help
My father in law found a Zenith 27" color tv by the side of the road. He repaired the broken power cord and it now powers up fine. The sound quality is also great. The only problem now is with the color blue. The red and green appear to be fine. Where would you start to troubleshoot this malady? The set is a mid 90's System 3 set.
Mike
Rob 12-08-2002 03:21 PM
Off Topic Alert!!!
ProAc,
See, it was curbside for a reason! :) Where would I begin troubleshooting this set? "I" wouldn't have picked it up in the first place! ...SINCE IT ISN'T A V-I-N-T-A-G-E color TV. ;) Now if that were a modern WEGA 40" Direct View I'm sure I'd have to confiscate it to set an example to others for abusing this newly created vintage color TV forum. ;)
If you want to try to troubleshoot there are others much better acquainted with fixing SS TV's than I. I think I'd get an o-scope and poke around the blue video amp which is likely on the CRT socket and see if there is trouble there. If there is blue signal then the CRT could have a dead gun. Oh, yeah, see if the 3 filaments are glowing (if it has 3). See, I don't know much about this newfangled stuff. :dunno: If there is NO blue video signal then you go progressively farther back in the circuit which carries the blue signal.
Careful, there are high voltages inside a color TV waiting to give you an unpleasant ZAP. If you don't have a basic understanding of the workings in there, don't take the back off.
Rob
kc8adu 12-08-2002 07:09 PM
the high failure rate of crt's in these is what sunk zenith.
i would check for blue video amp problems though because green seems to be the first to go on these.
lack of blue=yellow picture.
lack of green=purple or violet picture.
kc8adu 12-08-2002 09:07 PM
make sure you have an isolation transformer if you go poking around with a scope.
you should have one anyway as these new sets are hot chassis.
andy 12-09-2002 01:17 AM
Eric H 12-10-2002 01:25 AM
Problem solved
1 Attachment(s)
Mike, I found the answer to your problem :D
kc8adu 12-10-2002 07:22 PM
that looks like my dumpster after a shop cleaning!
julianburke 11-27-2007 08:15 PM
These sets were notorius for their bad picture tubes. They would lose a color and not necessarily a bad blue driver transistor.
MRX37 11-27-2007 08:35 PM
It's a mid 90's 27" Zenith. The picture tube is probably shot. If you have a CRT tester, you could check for emission levels/shorts, etc.
Try turning the color down to nothing and see if it has a good black and white picture. If the picture is tinted in black and white, the tube is shot.
EDIT: Wait! this thread's from 2002! Why was it revived?
