Old 11-17-2013, 07:56 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
A good reason to never "just plug it in"
Ah, the fun you can have at a friend's expense. He nearly crapped his pants when he saw this video
http://www.youtube.com/watch?v=qRasv...ature=youtu.be
Old 11-17-2013, 12:39 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Oh man, that's gold. Gotta love it.
Old 11-17-2013, 02:25 PM
Tony V's Avatar
Tony V Tony V is offline
Hey Tim...Bill C. would have a stroke wouldn't he? LOL!
Old 11-17-2013, 06:33 PM
Kamakiri's Avatar
This one belongs to BigAudioAl, but believe me.....I plan to show this to Bill tomorrow though
Old 11-18-2013, 12:31 AM
JBL GUY JBL GUY is offline
That is great.
Thanks for the link.
Old 11-18-2013, 02:11 AM
This just goes to show some of the worst post power up set failures are caused by the technician. :p
Seriously though most major smoke outs I've experienced were my own doing... I made the mistake of wiring the replacement doubler diodes backwards in my old Split chassis Philco which caused the good original caps to overheat, and then I replaced the 100 something uF doubler caps with a bunch of 22uF caps in parallel. I had it on a variac and had it almost up to voltage when I went to the dining room for diner...Some time later I started hearing regularish faint popping sounds from my room I ran back from the diner table and discovered that those 22uF caps were exploding one by one. About halfway between then and now I smoked B+ power resistors in two different rectangular Color sets from shorts. The first was my Zenith Chromacolor which during a focus repair (during reassembly after doing a cateract removal) I dripped solder on one of the above chassis terminals. I found that the original resistor smoked out so I just replaced it rather than trying to determine the cause...The replacement was an aluminum heat-sink cased dale power resistor. That thing went with a BANG! the moment I powered the set on. The other set was a single section of restuffed lytic that I wired backwards amazingly I was able to replace the resistor and reform the cap on my heathkit C-3 so one new resistor and cap wiring re-reversal later all was well.
The only hardcore old age cap failures I can recall were in my 9-T-246 I gave it a test power up and since there was no raster I feed a signal into the phono input and listened for a few minutes until smoke started creeping out and wax started dripping from a horizontal stage cap that let go. Later in that set's restoration I had replaced most of the caps except for two of the lytic cans....Then shortly after power up one of the cans started to hiss or whistle as the electrolyte boiled out the bottom.
Old 11-18-2013, 06:45 AM
Jon A.'s Avatar
I was in a hurry once hooking up one of my 8-track car stereos on the bench after a cleaning and lubing and hooked up the power in reverse. I was using 18-gauge blue/clear speaker wire for power, making the polarity less obvious. That smoked some transistors and popped at least one cap.
Old 11-21-2013, 10:01 AM
bigaudioal's Avatar
I literally jumped up off the sofa from a horizontal position and yelled, "WHAT IS HE DOING?!?!?!?!" Scared the hell out of my wife.
Good one! You got me.
-Al
Old 11-21-2013, 10:09 AM
Jon A.'s Avatar
If that was the selenium rectifiers going up, it would be more his problem than yours.
Old 11-21-2013, 11:38 AM
Celt's Avatar
Celt Celt is offline
Peanut Head
Tim, you are a baaaaaaaaaadd man!
Old 12-28-2013, 01:40 PM
CaryLee's Avatar
CaryLee CaryLee is offline
You got me on that one...that set looks REALLY close to the one I'm starting to restore..and I was quietly hollering "NOOOOOOOOOOOOOOOO!" until....well.....you know!!!!
....hardy har har!
Old 12-28-2013, 04:57 PM
TVTim's Avatar
TVTim TVTim is offline
That was a very well done video. Carry on.
Old 12-30-2013, 12:52 PM
soundman2's Avatar
soundman2 soundman2 is offline
Scanning The Skies
Oh, very good! LOL!
Old 01-01-2014, 02:45 AM
oh that's a riot alice , a real riot
Old 01-02-2014, 09:22 AM
DavGoodlin's Avatar
Motorola Minion
Imagine a nice loud fffffffffffffffffffffffftt - pop, with dielectric confetti raining down.
-Dave G
