Old 01-13-2014, 05:14 PM
devoid's Avatar
devoid devoid is offline
NA Volvos and Amplifiers
broke the panel
On my year old Panasonic TC-L42E5. I'm thinking I could replace it rather than the whole set. It's a LG panel. Marked lc420eun(se)(m3). Where do I buy one of these? Onlything new here to me is the tech. I've swapped out plenty of CRT's.
What I don’t want is music that was written to be recorded.
Old 01-13-2014, 06:19 PM
bob91343 bob91343 is offline
I replaced a laptop screen. Just google the model and you may find replacements. I think I paid about $65. Also, there were videos showing the procedure.
Old 01-13-2014, 06:56 PM
CoogarXR's Avatar
CoogarXR CoogarXR is offline
Swapping a large LCD panel is time consuming but not hard.
I would just keep checking ebay for a panel. Used panels are tough to find. I know the place I worked for, if a tv had a good panel, we fixed it instead of parting it out. I bet a lot of places use that logic.
You can figure out what other make/models that panel was used in too. You might be able to find a whole TV, different make/model, that doesn't work and get it for the panel. Just a quick look, it looks like the VIZIO M420KD and a few others use that panel.
Old 01-13-2014, 07:09 PM
Probably be easier to find a set with bad electronics and swap those. Changing a panel sounds like a lot of work!
Old 01-13-2014, 08:00 PM
Please pardon the off topic post, but I gotta ask; Devoid, what is your Avatar? I have seen that somewhere before, but can't place it.
thanks,
Old 01-13-2014, 08:27 PM
devoid's Avatar
My avatar from AK.
Back in the 90's, a long time ago, I fixed electronics for a living. And this Panny is real easy to work on compaired to other LCD sets I've worked on. Just need to find the panel. I got a lead from Alibaba. Will see how that goes. For an LCD I really like this set. Though my plasma smokes it. I'll see if I can find some other sets that use the same.
