Old 09-11-2018, 08:23 PM
Tellyrescue Tellyrescue is offline
Deader than dead CTC-9
Recently acquired this RCA CTC-9 metal cabinet set, yoke is charcoal along with the horizontal width pot. Knobs are gone and the cabinet has a nice scar on top right corner.
Hope to get it glamed up and working as a daily driver.
Old 09-11-2018, 08:26 PM
More pics
Old 09-11-2018, 10:08 PM
Great project-some real sharp repairs on that set! Proves that there were always hacks. Lots of fun to bring something like this back from the brink.
Old 09-12-2018, 12:14 AM
Penthode's Avatar
Penthode Penthode is offline
I have a CTC 11 which was similar. It was great fun solving the problems. The if coils had disintegrated and found exact replacements at a nearby electronics surplus.
Patience and dedication will see you though!
Old 09-12-2018, 12:25 AM
If the width pot is the one with the green wire and the brown half a lamp cord wire to chassis, and you judged it with your eyes instead of a multimeter then you may find that it still works...That one seems to use black plastic to hold the resistance material and terminals (instead of the brown phenolic of the other pots) and is likely still just fine.
The yoke is not so much charcoal as disintegrated plastic. The early plastics used for the outer shells on most yokes before the mid 60's were very unstable and will rot away on their own...This even happens to unused mint in box NOS specimens.
The windings and important core parts look fine and are probably still safe and functional. The shell can be recreated with a little effort with modern plastics. The part that usually rots away only acts as a mount for terminals as well as a guard to make it difficult for a service tech to accidentally grab those terminals with the set running (it also is supposed to be the grab handle to adjust the yoke).
You want to avoid touching the yoke terminals if the set is powered on...The meanest shock I've ever gotten from a TV set was a CTC-15 clone that I touched a portion of the yoke winding where the insulation was bad...That is the only time I can remember my 'let go of this' reflex kicking in full strength...
Old 09-12-2018, 10:11 PM
I measured the component out of circuit and it will need to be replaced as the carbon track is ruined.
Old 09-13-2018, 07:25 PM
irext's Avatar
irext irext is offline
I am fairly certain that yoke is cactus. A ring test should prove it. I've seen yokes looking like that before and they were all crook with shorted turns.
Old 09-14-2018, 01:57 PM
Sparky's Avatar
Sparky Sparky is offline
Working on one right now. Bad Bubblebees in the horizontal circuit. Nasty things that they are.
Dump the Black Beauties as well, and of course paper.
The set is like new now. Not to rub it in, just to say I feel your pain. Pix to follow...
Old 09-28-2018, 11:27 AM
Sparky's Avatar
The 106305 Deflection Yoke is a Y-107 according to my 1983 Thordarson TVPG-15 book. The Sams 459, page 11, doesn't cross it.
Check the horizontal centering pot on the flyback and the brown dipped caps in the vicinity, as well as the 56pF 6KV disc.
Mine were all off and leaking. The current went way down after replacement.
Old 09-29-2018, 08:24 PM
Good tip on the disc, never though to check it.
I had to replace the horizontal width pot as the fine wire was all tangled up inside and believe it shorted out taking the resistor on the back of it and the horizontal winding on the original yoke with it.
I also replaced the two caps in that area. I now have HV but it needs to be reduced.
Old 09-29-2018, 08:29 PM
Progress so far;
HV is 29+KV and turning up the horizontal makes it go higher.
Chassis is back out for resistor checks and cap replacing
Starting with the horizontal board and vertical board
Old 10-01-2018, 12:19 AM
Sparky's Avatar
ALL caps are suspect after another remote session today. I hope you have a good cap checker that has leakage & rated voltage like the Sencore. Check at the linearity coil. Brown caps were all leaking at 200V & 600V ratings. Try not to use any yellow caps in the AC current circuits. HV bypass is OK but not current. I know, as see you are using Orange Drops, but I am speaking to the uninformed.
BTW same tangled mess in the pot.
I guess your yoke is OK or is that another one?
Keep us posted!
Old 10-01-2018, 10:29 PM
Sparky's Avatar
The original complaint was that the horizontal wouldn't hold/breakup if close to lock.
I replaced some bumblebee caps in the horizontal section. Great go home.
Next is a call that the vertical is bad. I go back and fix the lack of vertical/height.
The next call is that there is no sound, just a faint buzz at high volume.
It was then decided to solder all ground supports for the boards and any suspicious areas as well.
I note that something is noisy in the audio detector area. Tapping there produces lots of loud noise in the speaker. Okay, change the 6DT6, nope. Narrowed it down to A11.
While I'm in there, I take out the very microphonic A11 the quadrature trap. Then I noticed it. A piece of half clipped wire still attached to the center leg to one of the outer legs, shorting the winding. This was factory, as it was still connected to its master wire. Removed, reinstalled and aligned. Nice audio. Shame RCA.
Let's check the flyback as it looked like a lot of wax was on the bottom of the box, not unusual for a 59 year old TV.
Gahhhh! there is the 56pF cap with burn marks across the ground side of the cap from the bottom 22MΩ resistor. Replace what I have with me, clean what I don't. I never could get the H centering pot to move. Let's look at that. Frozen or should I say burnt in place.
A 90 mile round trip ride later back to my house, I have one. Need some resistors that are burned up in there too. Remove and replace. All looks good. Tested and all is good again.
Now let's look at some more caps and test for leakage. Remove, replace, reinstall chassis.
It's now around 1AM. No video. Well there is. Out of brightness and focus with a blue tint. The CRT socket is apparently intermittent. Next visit We're done for the night.
Now to this Oct 1st weekend. I made up a socket assembly from a bare short clipped unit. I found wire to match the original colors, just because. Dissembled the TV and benched it to look at the dissembled socket by drilling out the rivets. One of the factory solder connections to something blue related (I don't care at this point) which was never done. Solder it. Shame RCA. Check the focus connection. All fuzzy white, with a corroded pin and receiver. Clean Clean Clean. Replaced the chassis and all is good.
Still seems a bit narrow though. The vertical is not filling the CRT as well. Boost Voltage. Check the B+ you say. A bit low. 340 something volts instead of the 385V. Before the filter reactor the same. Line voltage is optimal.
It's late again..... Parts on order for next weekend's failure adventure.
All this on a TV that looked good after the first repair...
Old 10-02-2018, 12:10 PM
That's a pretty good rap sheet, I'm feeling mine is gonna be a similar way, I don't hold much hope for the flyback lasting any length of time. But you never know.
Old 10-02-2018, 12:06 PM
Keep us posted!
Damn that chassis looks factory fresh! Can't say the same about mine, it's a little rusty and dirty.
