Old 11-22-2006, 09:47 PM
steve gibson's Avatar
steve gibson steve gibson is offline
AK Member
6Volt radio battery
I have an old Zenith battery operated radio I want to restore. What kind of battery should I use? Wet cell or dry? Would a motorcycle battery work?
Old 12-01-2006, 08:06 PM
Dan Starnes's Avatar
Gizmo Nut
I have not seen a 6 volt motorcycle battery in years. But alot of farm type stores still sell 6 volt tractor batteries. I have a 30 Ford Model A and that is what I use. Wet cell would be easy to recharge with a conventional auto type battery charger with the 6 volt option.
Dan
Old 12-02-2006, 12:38 AM
Randy Bassham's Avatar
Randy Bassham Randy Bassham is offline
AK Member
The best battery would be a 6 volt deep cycle the kind they use in RV's. The big ones are kind of pricy but will last longer than a starting type battery. Many RV's use 12 volts and will have 2, large 6 volt batteries in series which give longer discharge times between charges.
"proximo satis pro administratio"
KAØSCR
Old 12-03-2006, 11:35 PM
AK Member
Thanks guys. I've got a cheap dry cell and a rechargeable that actually is intended for an electric fence. The cabinet is done and beautiful. I recapped and I am waiting for a tube and SS vibrator to arrive. But I did have it powered up for awhile. Someone has screwed with the alignment which is outta my expertise so I may have to find someone to do that. BTW, it is a Zenith 4-V-31 tombstone.
Old 12-03-2006, 11:47 PM
Aage's Avatar
Aage Aage is offline
Custom User
Is it this one? That sure is a beaut, fancier than a lot of the farm radios were that's I've seen.
'Course, we don't see much in the way of the fancier old Zeniths here, sad to say/
Experience is what you get when you don't get what you wanted.
Old 12-03-2006, 11:58 PM
AK Member
That is the one. I will post a pic when it is done.
Old 12-05-2006, 01:20 PM
Chimes's Avatar
Chimes Chimes is offline
VK Member
You can pick up a battery eliminator on ebay for probably less then a battery and charger costs. Here are some current auctions for the Heathkit units. They will power 6 volt farm sets.
http://cgi.ebay.com/Heathkit-Battery...QQcmdZViewItem
http://cgi.ebay.com/HEATHKIT-MODEL-I...QQcmdZViewItem
I also have the 4-v-31 , they are nice playing sets.
Old 12-05-2006, 02:09 PM
AK Member
Thanks Chimes I am bidding.
