Old 11-06-2007, 10:21 PM
Got my Motorola Mask!!
Sweeet! This thing is excellent.
First thing I did when I got home tonight was install it.
It's a little tricky to install, it's a little loose in the case and you have to push the CRT firmly in so it expands and locks in, the mask is a little sticky so it's a bit difficult to get the CRT to slide into the mask with it in the cabinet.
I solved this problem with a little water based lubricant (i.e. KY jelly or equiv) applied to the mask, this lets the tube slide around but it shouldn't deteriorate the rubber.
I placed the cabinet face down on a table with a rag under it, I pressed firmly down on the bell of the tube and tightend the clamp.
(tip, fire the set up before you start mark the center line of the tube, this will make it much easier to get the picture level without having to pull the chassis several times like I did)
Many thanks to Blacksmith, you should be able to sell a few hundred of these!
Old 11-07-2007, 12:13 AM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
man that looks schweet!
I may send some $$$ his way for my moto...
Jordan
Old 11-08-2007, 05:09 PM
Dan Starnes's Avatar
Gizmo Nut
Yes, that is very nice!
Dan
Old 11-08-2007, 05:15 PM
Celt's Avatar
Celt Celt is offline
Peanut Head
Excellent!
Old 11-16-2007, 06:23 PM
kbmuri's Avatar
kbmuri kbmuri is offline
Got mine today. Completely acceptable. Guess I better dig into restoring the TV chassis...
Old 11-16-2007, 11:25 PM
looks nice.
I still have to get a VT-71 before I get one
Does it also wrap around the CRT ?
Old 11-17-2007, 07:40 AM
stromberg6's Avatar
That mask looks great! I must get one before Christmas so I can show off my VT-71 to the guests, along with the in-progress-now RCA 8" mini-portable.
Kevin
stromberg6
Old 11-20-2007, 10:53 PM
How bad can these masks get?
This bad!
Found this old picture of my set as I got it, the melted rubber pretty much covered the entire screen, there is still some residue inside the cabinet today.
Old 11-21-2007, 10:29 AM
blacksmith
Guest
Posts: n/a
This bad!
I don't think that was an original mask. I've only seen a couple, but one was still pliable, and the other one had turned to cement. If one turns rock-hard, how can another melt like that.
I would guess that the melted one was a repro that somebody made up from a material that didn't like heat.
I tested my repros with a heat gun. I got it so hot that I couldn't touch it without feeling pain, yet it did not get tacky or softer.
Old 11-21-2007, 10:31 AM
Dave S's Avatar
Dave S Dave S is offline
<-- Me and my "first" TV
I've seen a number of originals that ended up looking like a Dali painting. Fortunately, most of mine held up better than average, but they're all candidates for replacement by now.
Old 11-21-2007, 11:46 AM
I remember a pair of these sets in a local antique mall a few years back and both looked similiar to Eric's picture.
Old 11-21-2007, 08:44 PM
kbmuri's Avatar
http://cgi.ebay.com/motorola-golden-...QQcmdZViewItem
Case in point...
