Old 02-09-2008, 08:14 PM
chipper chipper is offline
Convergence Problems
HI: I have just replaced the CRT in my 59 RCA Boswell set, with a GE 21CYP22A. and have a problem with blue or yellow horizontal shading around figures or between sky and earth back grounds . the yellow usually shows-up in a b/w picture. I have hooked up my RCA WR-64B generator and have done all the preliminary adjustments.(degaussing/purity/gray scale) and have a great overall color picture except for this. When I put the generator on dot and pattern do the red/blue/green dots converge into 0ne white dot, if so how is that accomplished. also I need someone to walk me through the crosshatch pattern, my directions are not to clear on this adjustment. I would appreciate any help you could give me on convergence adjustments . thanks chip
