Old 11-23-2011, 08:07 PM
Nuke Nuke is offline
Admiral T102
Picked this guy up as a "covered with dirt and grime local" Craiglist find. The set actually played perfectly after a controlled power up while hooked to my cable. However, after a couple of power-ups, the visual image became distorted with the "big forehead" syndrome display first becoming evident, followed by shrinking vertical. I decided not to power this up anymore until I decide what I want to do with it. If anyone has the correct contrast and vertical knobs, for it. let me know. The set has a GE replacement CRT and it had an aftermarket antenna assembly screwed to the back, which I removed. (It was brown plastic and looked ugly).
