Becker "MB Sound System" amp analysis
A good trip to the junkyard netted me a newish replacement amp for my 1991 350SDL's audio system (the label on top says it was produced in 1996, it came from an 89 car).
![]() MB Claimed this setup was 25 watts per channel, for a total of 200w. Considering the physical size of the amps I was doubtful. So I took this one apart to see what makes it tick. ![]() ![]() A fairly simple device. The 4 chips mounted flat on the board are preamp / compressors, ST tda7232. http://www.datasheetarchive.com/pdf-...SA-634896.html The 8 mosfet's are ST BUZ71FI. http://www.datasheetarchive.com/pdf-...SA-561210.html The datasheet says they are rated at 17 amps continuous, with a quick pulse of 68(!). So I guess this thing really could put out that much power. The heatsinking really leaves a lot to be desired though, there's no thermal compound anywhere, you can see how tiny the internal heatsink is, and that just contacts the non-finned case to dissipate heat. The construction of the cabling to the amps is quite good though, the line level inputs run in a cable with 2 layers of copper shielding Overall the system preforms well in my car, but deep bass notes get really flabby. It's almost like it's overdriving the speakers. -Jason |
