Old 03-22-2013, 03:21 PM
radiotron's Avatar
radiotron radiotron is offline
johnny the raster master!
arvin chaissis cleanup gone wrong!
I have been cleaning up my 1950 arvins chaissis up the past 2 days, and had a good full picture almost all the way restored, i put the 5u4 back in, broke the socket! problem solved, turned the set on bbbbbbbbbbbbbbbbzzzzzzz
pop bell top 5u4 dead! one of the very few caps that tested good left in this is why we do FULL restorations!
also it almost cought on fire! i did get free confetti!
Looking for zenith cobramatic parts
-johnny the raster master!
Old 03-22-2013, 03:31 PM
ggregg's Avatar
ggregg ggregg is offline
free confetti from a blown filter cap I'm assuming........
Old 03-22-2013, 04:10 PM
Geist Geist is offline
Hi All;
Too bad you didn't get it on Video, It would have been a sight to see..
THANK YOU Marty
Old 03-22-2013, 10:32 PM
Einar72's Avatar
Einar72 Einar72 is offline
Chasin roundies since '79
Good thing it didn't blow into an eye! Been there, done that!
Old 03-22-2013, 10:42 PM
DavGoodlin's Avatar
Motorola Minion
Electrolytic caps can suddenly go crappy on you. I just had it happen to a '64 Zenith AM-FM H845, I tested the 4-section electrolytic OK, but it just started humming a bit more each day and I knew.....I was not done even though I replaced the wax-papers and put a silicon rectifier/series resistor in place of the selenium. should have been first on the list.
I bet the new 5U4 was putting out a bit more EMF..was there a phfffft sound first?
Old 03-23-2013, 07:31 AM
radiotron's Avatar
no, but i have heard that sound, this one i was watching, and it made a pop, then a loud hum i go to turn it off, and sparks confetti,(heck of a mess to clean up) and its being taken to grandpas this weekend
Old 03-23-2013, 10:28 AM
snelson903 snelson903 is offline
i just got done this week recaping my 1955 zenith , i think its the first time iv seen a set that every cap none polerized and electrolytics where all bad ,not one cap was even close to being good most just leaky. it turned out great nice sharp picture ,sound nice and clear ,after going through the tuner its like a new set now.
Old 03-23-2013, 03:30 PM
radiotron's Avatar
i found the culprit, it was a resistor went bad, and it took out the cap,
heres pictures before it blew (it was just restored, i didnt get to align it yet)
It has a kind of weak picture tube
Old 03-23-2013, 04:22 PM
I think it's more likely the cap went bad and took out the resistor.
Old 03-23-2013, 05:04 PM
kvflyer kvflyer is offline
I'm with Bob on that...
Old 03-24-2013, 11:17 AM
trojanrabbit trojanrabbit is offline
Saw a real good confetti storm once in a previous job. They were working on MRI gradient amplifiers (essentially a big honkin audio amp 300V @ 100A) and had a good sized capacitor bank (probably a dozen large caps) sitting on the bench with an insulator and a DVM sitting on top of it. The power source was a 600V/100A supply adjusted to 350V. One day we heard a hissing sound and someone yelled "DUCK". Apparently the power supply lost regulation and put out full voltage whatever that was. Big confetti storm and the DVM (an HP bench job) was thrown through the ceiling.
miniman82's Avatar
First Light: 1952-2011
Ya know, it's a good thing you work on B&W sets. I shudder to think how many rare color chassis you might have destroyed if you were a color fan, please learn as much as you can on these sets first.
Evolution...
Old 03-24-2013, 12:09 PM
radiotron's Avatar
i already know about these sets, and i do have colors too.
when i restored it, this cap tested good, it just failed.
its not anybody fault.
Old 03-24-2013, 12:10 PM
How did you test it ?
Old 03-24-2013, 02:32 PM
radiotron's Avatar
I used a scope
