Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > Early Television Foundation CRT Rebuilding Project
Old 04-10-2017, 03:49 PM
Crt cathode meterial
So crts have cesium alloy for the cathode meterial what's to say that the cesium if changed or recoated would the tube work again. I know there should be a coating over the cathode meterial to keep it from being contaminated by air so if this is done and pull a vacuum , would it work, without a getter.
Old 04-10-2017, 04:20 PM
SpaceAge's Avatar
SpaceAge SpaceAge is offline
With no getter, would you be able to achieve sufficient vacuum for the electron beam to function?
Old 04-10-2017, 04:45 PM
You'd probably have gas. Especially if you don't bake the tube during evacuation...Also HVAC vac pumps can't pull enough vacuum to be acceptable even with a gether in most cases (if that was what your planning).
Old 04-10-2017, 04:55 PM
Well I will try anything once if it didn't work that's ok too. I know the tube should be hot for awhile and it helps the vacuum when it cools. I don't even know what the cathode meterial is coated with to be heated off later after its done because it cannot come in contact with air so how would this cesium be put on, brushed and would there be a specific time it can be handled in air befor having to be coated. And what exactly is the getter made of, does it stick on the inside of the tube glass and then hit with high megnetic field to burn it on.
Old 04-10-2017, 06:17 PM
The getter is a reactive metal like magnesium....I hear some (home made radio tube) experimenters have taken ones from junk tubes and re-flashed them with RF induction heating rigs.
They coated the cathodes with some mix of the emissive material and another substance that prevents it from reacting with air (do some searches on vacuum tube and CRT making for the recipe). The stabilizer is burned off a during the final stages of evacuation or after IIRC.
Old 04-10-2017, 07:33 PM
You can bet that tube factories did not waste any money on doing unnecessary processes, so the answer to "will it work without (x)" is generally no.
Nick learned all the steps and is now practicing to prove that he really remembers it all, plus the few he has done will prove it if they last a good time (so far, so good).
Old 04-10-2017, 08:06 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
The cathodes didn't use Cesium, AFAIK. The cathode in most tubes is a high purity nickel structure coated with an active layer of barium and strontium (and sometimes calcium) carbonates. During exhaust, the cathode is heated, converting the carbonates to their corresponding oxides.
Cesium was occasionally used as a getter material in some tubes, and it is used as part of the photocathode in some camera tubes, phototubes, etc.
Old 04-10-2017, 08:26 PM
Correct! the duck should fly down and give you $100!
Old 04-11-2017, 01:22 AM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
This is interesting actually. We really need to have a comprehensive source of information for making/rebuilding tubes... Enough of the knowledge has been lost already, it wont be long before it's all gone forever.
Nickel for a cathode seems easy enough, but is it plated with barium or like just painted on?
Old 04-11-2017, 10:02 AM
Notimetolooz's Avatar
I believe a dot of a emissive paste is applied to the nickel cathode. Once in a vacuum the cathode is heated, the CO2 (+ H2O, etc.) is removed by the pump, leaving oxides behind. If exposed to air the oxides re-combine to for carbonates again but can also be contaminated but other things.
Rebuilding a CRT is very complicated, like rebuilding a bathroom from scratch. Many different skills to get right.
Old 04-11-2017, 11:52 AM
N2IXK's Avatar
Technohippie
Nickel used for cathodes needed to be ultra-pure, as even tiny amounts of certain impurities (particularly silicon) would greatly reduce tube life in some applications.
The amount of chemistry and materials science that went into tube manufacture is quite amazing. It was nearly as complex as semiconductor fabrication is today. Entire industries sprung up (and died) to service the electron tube business.
The closest thing I have seen to a comprehensive book on making tubes is the 1962 RCA manual "Electron Tube Design". Available here:
http://www.tubebooks.org/Books/Atwoo...e%20Design.pdf
Old 02-25-2018, 07:57 PM
dtryon dtryon is offline
Tube Building
Greetings,
As to the above post, is the rest of the RCA book "Electron Tube Design" available anywhere? I find the information from the link interesting but would love to see the rest. Can it be downloaded or purchased from anyone?
Thanks,
Dennis
Old 02-27-2018, 11:45 AM
N2IXK's Avatar
Technohippie
Entire book available here:
and here:
https://archive.org/details/RCA_1962...on_Tube_Design
Old 04-11-2017, 10:11 AM
Well while the materials may be available I think I will just let this thought of mine go since there seems to be a check list of things to do while other things are being done rebuilding a tube and if one is left out or forgotten then it was time lost including the tube .
It's not as simple as it may seem, that's for sure so maybe I'll wait for E T F maybe to rebuild any tubes I may have which is only 7jp4 tubes but there are no parts for them which then the gun would have to be rebuilt rather then just changed. from what I understand the cathode meterial was said to last a hundred years so why are there so many tubes with low or no emission due to cathode meterial.
Old 04-11-2017, 10:30 AM
That may be the shelf life, but CRTs and most vacuum tubes in general only have a service life (hours powered on) of 10-30k hours IIRC.
