Old 08-14-2013, 05:57 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
A three wire wax bypass cap?!?!?!
Working on this 1940-ish RCA AA5 set, and I run across this. In all the hundreds of radios I've had my hands in, NEVER seen one before. Worst part about it is that the marks on the cap don't correspond to the wires coming from the cap, so I'll have to find a schematic to see what's what.
Not sure of the model number of the set.
Old 08-14-2013, 06:27 AM
WISCOJIM WISCOJIM is offline
http://www.radioatticarchives.com/radio.htm?radio=11480
Old 08-14-2013, 09:26 AM
It's a 1AX, found in Riders 12. Coupling cap to 50L6 grid and tone comp to B-.
I don't remember seeing one of them in an RCA AA5.
Old 08-14-2013, 09:30 AM
egrand
Guest
Posts: n/a
Here's the Riders on Nostalgia Air: http://www.nostalgiaair.org/Resources/803/M0014803.htm
Is that the bottom of the 12SQ7 that it's connected to?
Old 08-14-2013, 12:47 PM
The values given in the Riders print are pretty smeared and hard to read, but look to be 300 pf and .005 mf (which sounds about right), connected thusly:
(Looks like a predecessor to the notorious 'couplates' of a later decade.)
Old 08-14-2013, 01:06 PM
Kamakiri's Avatar
That's exactly it, thanks! I don't stock anything below 680 PF, so guess I'll have to place an order
Old 08-14-2013, 01:41 PM
You could probably omit the 300pf one altogether, as it serves only to cut treble.
Also, judging by the large value of C17 (across the plate of the 50L6), the designers were trying to emphasize the set's bass response at the expense of treble.
Old 08-28-2013, 12:10 PM
Kamakiri's Avatar
I know why that capacitor is there....because it sounds like a tin squawk box without it
Thanks for the help! She's up and working great
Old 08-14-2013, 09:32 PM
put two 680 pF in series and you'll get 340 pF, which is close enough
Old 08-15-2013, 05:12 AM
Kamakiri's Avatar
You guys are geniuses!
Gonna finish it up when I get back from the Big Apple
