Old 09-25-2013, 10:08 PM
duckland 23's Avatar
duckland 23 duckland 23 is offline
famous sony KV40XBR800 BLINKING SEVEN FLASHES
My sony KV-40XBR800 IS blinking seven flashes . It will power on and run for one maybe two weeks or so or just a day . Only if I unplug the power cord to it . I also notice that when the fault with the seven flashes it will power up when I plug in the power cord , but if I leave it alone for 24 hours or over night unplugged she will act normal and If I hit the remote she will fire right up normal . Im told the Sony MCZ3001D chips are bad and need to be changed . I ordered the chips from ebay last week . Im going to install them on Friday .Im hoping that all go's well and it fixes the problem . I really like this set . After all it was given to me from a man from craigslist . Its beast and is very heavy to lift . Im not going to take the the D board out if the unit all the way just to have the room to solder the chips to the board . Im going to use the supplied sockets that came with them from ebay .
So let me know what you think and if I should check any of the caps that are in the circuit . I hear there's couple of problem some caps too which ones are they would you know by chance . So let me know .
thank You
