Old 10-18-2013, 11:51 AM
Sonora 302 restoration
I wanted to squeeze in one last major refinishing job before the cold weather arrives. eenie meenie miney mo - this Sonora 302 is it.
Here's the thread from when I got it last year: http://www.videokarma.org/showthread.php?t=254990
It's an interesting design that uses a variable capacitor for continuous tuning. Looks very easy to work on
Over the last year, thanks to some reference photos from Eric H and a lot of luck, I was able to track down a complete set of knobs including the continuous tuning channel plate!
This is easily the crappiest cabinet I've encountered. It's a basic plywood box with little bracing and mismatched veneer. As you can see, it's warped over the years especially on the side with the missing brace and the top.
The top is also stained and nasty looking.
I started by removing the brass trim, safety glass and metal bezel. Then moved on to reinforcing the cabinet.
I used a sturdy piece of oak across the top. That's better! I later had to cut out an arch otherwise the CRT wouldn't fit inside.
Here's the cabinet after stripping. I also used a little bleach on top to remove the worst of the staining.
As you can see, it's mahogany.
As for this side, I'm not sure what it is exactly. Low grade mahogany ? Cherry ? It sure doesn't match the top or other side.
All patched up, grain filled and ready for some color
