Old 04-14-2015, 11:31 PM
sweitzel sweitzel is offline
Who's CT100 is this?
Just spotted on ebay:
http://www.ebay.com/itm/Rca-Ct-100-1...ypes=og.shares
If the URL above does not work search ebay for item number 281658020830
Shortened URL here: http://tinyurl.com/kzwrqh2
I know it's a CT100 but the asking price seems a bit on the high side?
Old 04-15-2015, 12:23 AM
Good 15GPs are very scarce to put it mildly. Unrestored CT-100s were fetching 10K a few years back. I could see it fetching that price or close to it.
Old 04-15-2015, 02:12 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Whoa, still under vacuum.
It'll be interesting to see where this goes.
Old 04-15-2015, 02:23 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
It's only an hour away from me, if anyone's interested in buying it and needs someone to see it in person......
Old 04-15-2015, 01:55 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
The owner of this CT-100 named Pat contacted me thru my website. He told of the problems he was experiencing w/his CT-100. I replied that I am more of a color tv historian than a technician and referred him to Videokarma's early color page. I also mentioned my CT-100 is on the disabled list. Nice bright raster but having focus problems. I wish he had posted a photo of the complete set. And the previous photo when the set was working.
-Steve D.
Old 04-15-2015, 05:55 PM
Patrick H Patrick H is offline
I am the seller. I had posted 12 pictures and all but 2 disappeared. I am out of the country so I ended the auction and will resist with all pictures when I get home so stay tuned. This issue made me see that it needs to be with someone who can maintain issues as they come up. Does anyone have any idea what the fix could be? I need to turn the brightness all the way up and can only get a blue screen.
Old 04-15-2015, 07:49 PM
miniman82's Avatar
First Light: 1952-2011
Probably bad peaking coils (the dreaded white crusty ones), mine was full of them and so was my 21-CT-55. The matrix output section alone has 6 of them, if not replaced they all eventually go bad. There's others though: in the luma path there's 2, the color sync section has one, demod, IF and nearly every other circuit they are present. If those were already changed out, it could still be bad caps. I redid a CTC-7 a while back with all new caps, and a few have gone bad since then. TV's are brutal on caps, especially the power supply and horizontal output circuits.
I think what you need to do is have someone stop by with knowledge of these sets, instead of selling it. It's likely to be something easy to fix, after all the CRT works and that in my book means it's totally worth bringing back to life. If it were full of air, I'd tell you to sell it.
Evolution...
Old 04-16-2015, 09:18 AM
dtvmcdonald's Avatar
Its unlikely a single peaking coil could cause that, it would have to be more than one in the DC restorer circuits.
My CT-100 that I restored last summer had the same problem at
first light, and it was a bad resistor in the CRT screen/brightness
divider chain. However, my set still produced a (color) picture of
sorts with the master brightness all the way up and the color
gains up. I don't think that any single peaking coil can destroy the picture,
just remove R, G, B, or luma.
Also ... my set was frequently displaying the same symptom as the OP's
last fall. The set was perfect! The cause was a bad cable connecting
video to the input of the RF modulator; changing to a station
with no signal restored perfectly normal video noise.
Old 04-17-2015, 06:07 AM
miniman82's Avatar
If you know CT-100's, you'll know that it's ALWAYS more than one bad peaking coil.
Evolution...
Old 04-15-2015, 08:04 PM
stromberg67's Avatar
stromberg67 stromberg67 is offline
Hi Pat, wondering if you got my questions on ebay. I asked if the cabinet number is 827, and if the tech's initials are KS.
Thanks, Kevin, stromberg67
Old 04-15-2015, 08:14 PM
The schematic is here.
http://oldtubes.net/library/free_man...assis_CTC2.pdf
And further service info and alternate versions of the schematic can be found here.
http://www.earlytelevision.org/tv_sc...color.html#rca
Get or borrow an oscilloscope and trace the signal forward tube by tube from the DVD player's input (to the set) to the base of the CRT. The point in the chain where you loose the signal will be just past the fault. So once you loose the signal back track part by part until you find the exact place the signal is lost. Then test and or replace all parts in the area of the failure. Signal tracing like this is probably the most simple and direct approach there is to this....Voltage and resistance checks on all the video stage tubes and CRT versus the schematic may also help move you towards a solution.
Old 04-15-2015, 08:17 PM
The cabinet number is 26. The tech is KS
Old 04-16-2015, 05:46 PM
stromberg6's Avatar
Thanks Pat.
Kevin
stromberg6
Old 04-15-2015, 08:19 PM
I would love to keep it but I see now how difficult and costly to keep them working. Probably needs to be owned by someone who knows how to fix when it goes down
Old 04-16-2015, 07:48 AM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
Why do these things always have to be half way across that galaxy. Would love to have it.
