My new Philco 40-180
I scored on the World's Longest Yard Sale the other day! I got this gem for only $30. The veneer is in excellent shape, the only thing I did was polish it with GOJO. It plays and sounds quite good considering I just got it home. I still have to fix the dial string, though.
The set must've looked real sharp, when the push buttons were lit up by the dial light. They were somewhat translucent.
Ya did good on this one and got lucky too
Compared to 41-42 Philco sets, only ONE condenser block is used in this chassis which should make recapping easy. Just my 2c but the 84 rectifier tube should be replaced by two 600V rectifier diodes and a power resistor. Cheap insureance for your transformer. I had to buy those wine-colored pushbuttons and an audio output transformer for a 40-195 I restored. Antique Radio Supply has those buttons and they do look nice lit up!.
"When resistors increase in value, they're worthless" -Dave G |
I worked on one that looked like the transformer had been replaced. The previous tech changed the socket to use a 7Y4, instead. The older couple, that owned it, bought it brand new and mentioned how much they paid for it and the store name.
I think the odd numbered 1232 RF amp is same as a 7G7
I have a couple of Zenith branded 1232's. One has both numbers, 7G7/1232.
The rectifier installed in this radio is an 84/6Z4. I thought the only tube that should be replaced is the 6X5 in other radios. And I've also heard speculation that the later 6X5GT's are fine. I asked about this on the Philco Phorum, but nobody seems to care to reply.
Really nice score on that one, I have always liked that cabinet design. I was not aware of any issues with the 84 rectifier tube, I have a couple radios that use that tube. I don't play them very often so will leave them alone but be worth keep an eye on.
Gregb |
Thanks, all of you. You folks seem to be more considerate than those of the Philco Phorum, I appreciate that. This Saturday, I'm going to take this radio to the AHRS and restring the dial cord and clean the controls. Possibly replace the electrolytics, if they haven't been already.
