Old 09-09-2015, 08:09 AM
Doug66 Doug66 is offline
Emerson 1146D Fusible Resistor
Does anyone have the Sams for an Emerson TV Model 1146D? It's either 298 or 299 Folder 4. All I need is the value and wattage of the fusible resistor connecting to the selenium rectifier.
Thanks in Advance
Doug
Old 09-09-2015, 09:20 AM
WISCOJIM WISCOJIM is offline
5 ohm, 5 watt.
Old 09-09-2015, 09:52 AM
Thanks in Advance
Doug
Way back in the day, I used to carry 5.6 and 7.5 fusible resistors in the caddy. Most of them plugged in.
The set must be one of those 14" AC-DC jobs.
I need a 14HP4 for one. A 14QP4 will work, as well.
Old 09-09-2015, 10:38 AM
Its 5 ohm 5 watts. Use a 5.6 ohm its the common value.
Be sure its FUSABLE.
Old 09-09-2015, 10:41 AM
Findm-Keepm's Avatar
Followin' the Rules...
http://www.talonix.com/shop/category.aspx?catid=214
Odd that the Sams shows a PW7-5, a 7-watt resistor made by IRC. Over-rated, and not fusible. Another example of how following the Sams for parts replacement could be a bad thing.
Brian
USN RET 22YRS (Avionics/Cal)
Old 09-09-2015, 02:31 PM
Or use an inline fuse holder and fuse in series with it.
Old 09-09-2015, 06:38 PM
Thanks for alll the input to this. I had recapped the set and negelected to replace the resistor.
Old 09-15-2015, 05:24 PM
Ok, I had to replace the fusible resistor, rectifier, and fuse, but the set is playing again. I have one issue, and it's not one I have encountered before. There is some horizontal pulling in the picture, but it starts at the bottom of the screen, moves upwards, then repeats. I've encountered barkhausen oscillation before, but this is a horizontal line. I have replaced the damper tube and swapped the 6SN7 sync amp and horiz AFC tubes which didn't change anything.
In the pic, the issue is at the lady's head. If someone can give me an idea of the offending circuit, I can know where to start troubleshooting.
Thanks
Doug
Old 09-15-2015, 09:22 PM
That will work. A caution on fusables. At an RCA seminar a few
complained that the fusable always opened & not the fuse. TRUE !
They said its because the fusable protected the fuse. TRUE !
Bottom line is when you turn on a set there is a very heavy
current draw to charge up the filter cans. The fusable limits
that & lets the caps charge slowly. If it wasnt there the fuse
would soon fail. It also acts as a fuse, I have only seen them open
with a shorted rectifier or for NO reason, just age. Sets with
them rarely blew fuses !
Last thing is its important on solid state sets with kick-start
circuits. They depend on the slow & proppor rise of the B+ often.
Old 09-16-2015, 03:31 PM
One question on the electrolytics. C1A and C2A called for 250uf. All I had were 220uf, so I used them. Could that be causing the problem? If so, I'll parallel a 33uf with each before I start bridging new filter caps in.
Also, on the 5U8 AGC rectifier. Pin 1 should be -.9V. I have -5.97V. Pin 9 Sb -.3V. I have -4.27V. I did replace R30 and R31 coming off pin 1. I had replaced C37 when I did the initial recap.
Old 09-16-2015, 04:39 PM
Zeno,
Remember the Surgistors? The resistor that heated up and closed a bimetallic strip that carried the current? Workman and GC had replacements - I still have a couple, and may add one to my Setchell Carlson.
As to fusibles - Workman had several types - the heavy duty white one, the pink ones in 4.7, 5.6 and 7.5 ohms, and a square cement version called "FUZIT" that they sold in packs of 5. Philcos, RCAs and Sears sets I remember were the fusible killers - always opening up. RCA had one that was soldered to a little phenolic strip, and they dipped the whole thing in varnish. You could tell one had failed - there were flakes of varnish around the resistor.
Nowadays, it's smart to add a CL60/80 NTC in series with the line. Folks think it's something new, but surge/fusible resistors have been used for years, i tell 'em.
Brian
Old 09-27-2015, 10:36 PM
DavGoodlin's Avatar
Motorola Minion
This was a good thread for anyone with a series set. I have the same set with worn and faded tan covering. Red seems like a good idea. Eric H had attached an advertisement for it with red tolex, which looked right with all that gold trim. http://www.videokarma.org/showthread.php?t=262373
I got side tracked but its still on my bench
I replaced the electrolytics in mine, then powered it up slowly and there is a short in the filament string causing the 12BY7 to light up bright, with the remainder dead. I will replace the fusistor with a CL60 thermistor, series fuse and resistor. Great Idea.
-Dave G
Old 09-27-2015, 10:47 PM
Gregb Gregb is offline
I have this exact same set except it is branded Canadian Marconi
Gregb
