Old 02-08-2009, 12:38 PM
BroonsBane's Avatar
BroonsBane BroonsBane is offline
Raisn it up waxen it down
So What Have I Got Here Boys?
I picked this up yesterday as non-working and sure enough it lives up to its billing. Being a Telefunken tubed unit apparently made for the domestic market I can't read anything on it as it's in German, other than recognizable city names on the dial.. Is this a shortwave?
Yamaha B-2x/C-2x/T-2x Denon DP-59L Arcam Alpha Energy C8's
"Music is the best"
FZ
Old 02-08-2009, 12:53 PM
Looks like std broadcast band & shortwave.
Old 02-09-2009, 01:44 PM
electroking's Avatar
a- v- karma member
... and longwave as well, being an European market unit. The marking
of the shortwave scale in meters (wavelength) only and the other two scales
in frequency only is interesting! Good luck with this project!
Old 02-09-2009, 01:53 PM
MJSNet's Avatar
MJSNet MJSNet is offline
"Who, me???"
VERY COOL FIND!
Old 02-08-2009, 01:38 PM
ablethevoice's Avatar
ablethevoice ablethevoice is offline
boatanchors rule!
Location: NW FloridHell panhandle. Ivan and Dennis survivor.
Wow! Beautiful find there! Absolutely a prime candidate for a complete restoration. And yes, that's definitely a shortwave radio. I'm no Telefunken scholar but I'd guess that it probably dates from probably 1956 to 65
Old 02-08-2009, 02:19 PM
jonboy55's Avatar
jonboy55 jonboy55 is offline
Radio is from 1948/1949 according to: http://www.radiomuseum.org/r/telefun...a_8h64gwk.html
A schematic is available at:
http://www.tsf-radio.com/nav.php?rc=tome0/Telefunken
It's a beautiful radio. Best of luck with it.
Old 02-08-2009, 05:31 PM
Dave A's Avatar
Dave A Dave A is offline
Homebrew help?
Oops...wrong place. New thread started. DA
Last edited by Dave A; 02-09-2009 at 08:25 AM. Reason: Moved to a proper new thread...oops.
Old 02-09-2009, 09:59 AM
ke4mcl's Avatar
ke4mcl ke4mcl is offline
gear avalanche!
yep, its an older one. notice the use of real wood versus pressed termites with veneer on top.
ke4mcl
light travels faster than sound...
this is why some people appear bright until they speak
Old 02-09-2009, 02:22 PM
jetblack's Avatar
jetblack jetblack is offline
Love Those Tunes
There's some history behind that beauty!
MX136, MC501s, MC402, MCD500
RtR 300Ds, Mirage BPS 150i & OM-C3, JBL 2600s
Harmon Kardon HK 400xM
Dual CS 606, Ortofon 2M Black
Old 02-12-2009, 11:16 AM
ianj ianj is offline
Its about 1949, and a basic model. From around this time, many German sets started to include vhf-fm. Nice clean set!
Old 02-12-2009, 11:40 AM
BroonsBane's Avatar
Thanks folks, she is a beauty for sure. I'm not sure what I'm going to do with it as I am unable to restore it myself. I love the look of it though and after a good cleaning it will look even better.
"Music is the best"
FZ
Old 02-16-2009, 11:24 PM
Nortonrider Nortonrider is offline
Nortonrider
Translation
Although no technical specialist, here is a rough translation of the text on the rear panel:
Upper right, next to tube diagram: "Beleuchtungslampe" (Illuminating lamps)
18 V 0.1 A.
-- "Sicherung" (Fuse) 0.5 A
Antenna - ("Erde" -- earth or ground)
"Gleich - und Wechselstrom" (DC - and AC) 110 V/ 125 V; 220 V : appears to be a two position radial switch below this script.
"Tonabnehmer" (Sound pickup) 2. "Lautsprecher" (Speakers)
"Nuer fuer Tonabnehmer nach VDE Bestimmungen" (Only for sound pickups which meet standards set by the the Association of German Electricians)
"Nuer fuer Lautsprecher nach VDE Bestimmungen" (only...speakers meeting...Electricians)
Switch at bottom right: Sound Pickup
"Aus" Off
"Ein" On
"Vor Naesse Schuetzen!" (Keep unit dry -- literally: Protect or keep away from wetness)
"Vor der Abnehmen der Rueckwand Netzstecker ausziehen." (Pull the plug before removing the rear cover)
Dave
Old 02-16-2009, 11:32 PM
Nortonrider
Two corrections:
Lautsprecher (speaker)
Naesse (moisture)
Old 02-16-2009, 11:48 PM
Nortonrider
A couple notes on the cities if you're unfamiliar with the German names: (Muenchen) Munich, (Strass..), Strassburg/Strassbourg, Mailand (Milan), Wien (Vienna). RIAS Berlin (Radio in the American Sector, Berlin), Mosk (Moscow).
Old 02-16-2009, 11:56 PM
Nortonrider
One more --Beromuenster-- I think is Minsk.
