Old 07-01-2016, 09:55 AM
Motorola TS 4J
I bought a 7" portable style, Motorola at the Wheaton swap a few weaks ago.
As mentioned before, it is the most complete set of its type, I've run across. Everything was included! The seller thought the CRT is good, which it is!
Looks like, the last time it was repaired was the early 50's. Mine has the eight position tuner and a build date of Jan, 1949, no channel one.
I want to order all the HV capacitors, .001, .005 mfd @ 6000volts.
I'm going to order the ASC brand from Allied, as I understand that using ceramic capacitors can cause non-linearity issues.
It's going to take a lot of work to bring this one back, but it will be definately worth it.
