Old 12-13-2017, 10:10 AM
Cap ID
Can anyone identify this cap ?
Old 12-13-2017, 10:44 AM
1.2 mF @ 600v
Old 12-13-2017, 10:45 AM
broadcaster broadcaster is offline
It is a .022 mfd at 600 volts
Old 12-13-2017, 10:47 AM
Bumblebee color code chart. The colors have the same numerical value as Resistors.
Old 12-13-2017, 11:16 AM
I see 1200 mmf, 5% @600V.
Old 12-13-2017, 12:38 PM
EdKozk2 EdKozk2 is offline
Tinker
I see the same, assuming first color band is brown.
.0012 uf, 5% @ 600v ; physical size looks right too.
Old 12-13-2017, 06:44 PM
Ok so this 1.2 cap is for the horiz in this little RCA 8 inch black and white set I have a picture but it's 3 images and cannot adjust it out with the horiz adjust which states in the schematic horiz frequency adjustment. Checked resistors , tubes , did caps around the horiz just cannot get it. There is a 390 mica off pin 7 of the 6cg7 horiz oscillator tube to ground, so maybe I'll put Micas together to make 390 and see if this helps otherwise any help would be great. The cap with the color codes above that I asked about is .0012 on the schematic so I put in its place 1200 pf mica so it should be ok but the frequency is obviously wrong because of 3 images. I have an app that coverts NF to PF so I don't know maybe it's wrong.
Old 12-13-2017, 07:05 PM
irext's Avatar
irext irext is offline
Is it not .012 5% 600V? In other words 12000pf or 12nf. ie 1st two bands are brown and red (12). The multiplier is orange (1000) then green is the tolerance (5%) then blue is the voltage (600V). (The third band looks orange on my screen)
Old 12-13-2017, 07:19 PM
Well either way I found the cap in the schematic and its .0012 and I assume it's NF so in pf I just want to make sure 1.2 or 1200 pf is the same.
Old 12-13-2017, 07:22 PM
This cap is C-74 on the sams for the RCA 8PT series it is stated to be .0012, 600v.
The color code I see in the cap. in question is brown red red green blue or 12x100, 5%, 600V which agrees.
1200 pf equals 1.2 nf equals .0012 mf (sometimes written just .0012 or .0012uf).
Old 12-13-2017, 08:12 PM
Tinker
Timmy what model set/ chassis are you working with?
Old 12-13-2017, 08:18 PM
The set I have is the kcs100b .
Old 12-13-2017, 08:42 PM
I looked at the schematic at the ETF website. The only .0015 @ 600 volts is in the boost circuit.
I'd be more interested in the .01 mfd across the sine wave coil. That determines the horiz frequency.
Old 12-13-2017, 10:02 PM
Tinker
The .01 uf cap is connected across Coil L16, horizontal waveform adjust. If this is set wrong the picture won't lock horizontally. As dieseljeep noted.
Old 12-14-2017, 04:42 AM
The .01 uf cap is connected across Coil L16, horizontal waveform adjust. If this is set wrong the picture won't lock horizontally. As dieseljeep noted noted.
The sine wave coil on the schematic I have from ETF shows that coil as L155 unless there is another listed as L16 . The .01 cap across the sine wave coil I changed already with no improvement and I checked the coil it is not open. So it won't be easy to watch 3 images , lol .
