Old 08-14-2018, 12:57 PM
Tony F Tony F is offline
G.E. 810 found
I managed to pick up a G.E. 810 that is mostly in good shape. Cabinet will need re-gluing in places. I tested the 10FP4 picture tube, and it is pretty good for emissions. It must have been a replacement as it is dated 6-60 . Also, it is a G.E. tube. It has a massive 25Hz transformer, that goes nearly to the top of the cabinet. It is missing the GE brass trim button and one inner knob. Also missing the back cover. Here are some pics. Cost me all of $50 cdn. (That's $38.20 U.S.) The seller told me he got it from an auction more than 20 years ago. It has been in storage since. Sellers photos.
Tony
Old 08-14-2018, 01:33 PM
Hey, that's a good price! I just started working on the very same (well, US) model. I have only gotten as far as testing the tubes & cleaning it up.
Phil Nelson
Phil's Old Radios
Old 08-14-2018, 02:20 PM
Here are 2 more photos. The finish loss along the 1 edge (top) needs re-gluing. It must have maybe sat in a basement up against an outside wall to get like that. It looks worse than it is, just finish loss with no problem with the veneer. Also, the metal power (inter-lock) is missing. I ditched the power cord as it was 8' of crumbling rubber and wire. Phenolic antenna connector is also broken. I'll have to straighten the metal part that is wedged under the chassis.
Tony
Old 08-14-2018, 04:48 PM
WISCOJIM WISCOJIM is offline
Wow, that is a big (and heavy) transformer.
Nice find at a nice price. Congratulations!
Old 08-14-2018, 06:39 PM
For comparison, here's a view of the power transformer in my US GE 810 . . . much smaller!
I see that you are also missing the metal rear cover for the HV cage. I guess I'll make a new one from sheet aluminum. It appears to be fastened with a single screw at the cage top. Apparently the HV cage has no cover on the other (front) end -- at least, I see no means to attach one.
Phil Nelson
Phil's Old Radios
Old 08-15-2018, 12:37 PM
Phil Nelson
Phil's Old Radios
It is probably fastened by two screws. My guess is the bottom screw is the one on the back chassis apron under the Horiz Output tube.
Old 08-18-2018, 03:35 PM
Tom9589 Tom9589 is offline
Interesting schematic. They use a dual selenium rectifier to supply DC to the filament of the mixer/oscillator. The filament winding for the 5Y3 is also used for the CRT. I guess they were concerned about having the CRT filament too close to the ground and filament to cathode shorts. GE did the same thing on its Portacolor set.
I figure the replacement transformer didn't have the two extra taps for the 5Y3, so they installed a dropping resistor between the 390V and 310V sources.
Old 08-20-2018, 10:20 AM
Am I correct in remembering that Canada had 25 Hz power near Niagra Falls at one time? Is there something easier about generating 25 Hz than 60 Hz? Lower RPM of generating turbines?
Old 08-20-2018, 11:37 AM
Tom, I believe you are correct on both points on power generation from the falls.
Here are a few photos of why the transformer is not original to the set. 5Y3 rectifier (wire stubs cut and left). The one phenolyic "standoff" has the same leads just cut and left. One of the electrolyic can caps still has a wire "stub" sticking out from being cut. I also checked the power transformer mounting holes. They appear to be the same dimensions as the original as they were not re-drilled to fit this one. There are a few more bits of evidence of previous repair work. Although, "most" paper capacitors appear original. Also a few resistors appear to have been changed at some point. I spent quite a bit of time cleaning the flyback and area, removing "oily dirty muck" with ammonia on q-tips and following up with naptha. Naptha is also excellent at removing dirt from the flyback itself. It looks like new, however I would NOT recommend using ammonia on the flyback itself, just the surrounding area (insulating phenolyic) and wires. I didn't take any "before" photos. It was completely BLACK with crud.
Tony
Old 08-20-2018, 12:05 PM
Wow Tony, I've seen some NOS flybacks that didn't look as good as the one you cleaned up. The wire stubs on the 5Y3 socket have red/green insulation which corresponds to the power transformer taps for the 5Y3 plates. I would be curious as to how the previous repairman dropped the B+ from the 5U4 level to the 5Y3 level. I'm still betting on a big power resistor.
Old 08-20-2018, 12:57 PM
It is possible that set came from the factory as a 60Hz model and was converted to 25Hz by its owner.
Niagaras 25Hz was IIRC among the first AC plants. Niagara was originally going to be a compressed air plant and the turbines etc were built before the decision to make electricity... the easiest frequency to use to work with the mechanics was 25Hz and there was no other AC around to worry about compatibility with so that is what they did.
Old 08-20-2018, 09:01 PM
We also have to remember in the early days of electricity in the home, it was used for lighting and light bulbs didn't care about frequency. Neither did electric (resistance) heat and cooking.
