Old 04-07-2022, 09:53 PM
jass jass is offline
Philco Predicta board lifted trace and trace corrosion.
Hello i am new to this forum and a relatively newcomer to the hobby of tv repair so I work slowly but surely . I'm working on a Philco Continental with the 10L43a board. Removed the board from the chassis and discovered this lifted trace under the Horizontal output tube as well as the corrosion on the B+ trace line. Both the lifted trace and corroded B+ test good for continuity. I will be replacing the Horizontal tube base. Looking for advice on how to re-attach the lifted trace and and deal with the green corrosion Thank you
