Old 11-30-2023, 07:08 AM
CBS Columbia b&w
Since I got this set done works nice but when it’s turned on and the picture comes on it’s mostly white like the contrast is not there until about a minute later the picture darkens and looks good any quick ideas what may be the culprit.
Old 11-30-2023, 01:37 PM
Most likely a tired picture tube, with poor cutoff, which slowly gets better as it warms up.
Old 11-30-2023, 02:02 PM
That was one thing I thought of but I don’t remember how good the cutoff was I would have to test it again.
Old 12-24-2023, 09:43 AM
So I noticed the focus is lousy when first turned on and I see there is an ion trap and a focus magnet would that be the rings on the neck one for centering and the other for focus ?
Old 12-24-2023, 12:42 PM
init4fun's Avatar
init4fun init4fun is offline
If the focus gets better as it runs, I'd leave the adjustments alone. If you adjust it to look good when it's first turned on, wouldn't that make it look worse as it warms up, VS better?
Old 12-24-2023, 06:20 PM
Sounds like the classic soft CRT.
Old 12-24-2023, 07:25 PM
Soft ??
Old 12-24-2023, 10:25 PM
Soft ??
"Soft" is a way of referring to a worn-out cathode, so when the video highlights try to draw more current it doesn't provide as much current as it should and makes the spot bigger and out of focus.
Old 12-26-2023, 03:14 PM
So I guess this crt is not soft as we thought I put the tester on it and the needle bearing moved so I did the remove shorts just a quick touch of the button and a little spark inside and immediately the needle jumped up to 500 on the scale which only goes to 600 I didn’t try it yet but I’m sure focus and contrast is good. The cutoff tests excellent so I’ll see shortly. Tin whiskers inside I guess don’t know how these shorts form.
Old 12-26-2023, 06:35 PM
Anyone have a ge crt code book to see what year this tube is 6113 is the code
Old 12-26-2023, 10:18 PM
Don't know aboout GE for sure, but some makers' 4 digit codes are year and week, so 6113 could be 13th week of 1961.
https://www.ecianow.org/assets/docs/...g%20Format.pdf
Old 12-28-2023, 08:03 AM
This Columbia won’t pick up air waves with an antenna but cable wire works fine it has an agc pot and if that is far out adjusted would this keep it from accepting the antenna signal. All my other b&w sets work with a cable wire and an antenna in house except the Columbia makes no sense
