Old 03-05-2024, 10:26 PM
pac.attack76's Avatar
Stuck in the past
Unknown year General Electric YM-E
25" console powers on. No screen or audio. Just the channel display and gun lights up. No smoke or odor. Also wondering what year this one is.
Genesis does what Nintendon't
Old 03-06-2024, 09:54 AM
Mid to late 70's Look for 4 digit date codes on large parts.
GE is like Zenith. You need to be sure the S-cap is not a white one.
A bad one can blow the HOT, FBT & Vert out.
Look around, it may have a 'mini manual" in there.
Its dead so should be easy to fix.
Old 03-06-2024, 09:59 AM
Per tag. mini manual is on cabinet back. ( if its still there !)
Old 03-06-2024, 10:11 AM
Stuck in the past
That customers service information behind a plastic cover on the back is missing. It shows where it should be stored but not there 😔
Old 03-07-2024, 10:15 AM
Stuck in the past
Where is the s cap located?
Old 03-08-2024, 08:53 AM
Not sure but on the portables its behind the HOT heat sink.
Old 03-09-2024, 03:32 PM
colortrakker colortrakker is offline
Thinking in color...
Man, that's a flashback. Aunt had one of those for 10 years - very similar to this one. Nov. '78 build, and the channel readout was not a real LED. VIR, of course. Guessing this one is a year or two newer.
Good headphones make good neighbors.
Old 03-09-2024, 10:37 PM
rcaman's Avatar
rcaman rcaman is offline
flyback ep77x30 or ep77x33 i believe changed a lot of those. see if the circuit breaker is tripped.
Old 03-10-2024, 09:22 PM
Stuck in the past
If breaker is tripped, would the gun and channel still light? I doubt it but who knows.
Old 03-12-2024, 10:52 PM
Most 60s color sets the breaker was between the B+winding and the B+ rectifiers so if the breaker tripped you'd loose everything except the heaters and dial lamps.
Old 03-13-2024, 10:23 AM
Stuck in the past
Learn something everyday, lol. I'll look for the s cap tomorrow. Supposed to rain so I'll be in most of the day.
