Early 60's as the new season approaches
Its almost fall and the anticipation of the new television season has you guessing as to which shows coming on this fall will be colorcast. Gee maybe ABC and CBS will break out some of their sparsly used color broadcast equipment. I'd better check my Channel Master yagi antenna to make sure all is ready for the upcoming season, maybe I'll switch to some of that coxial cable that I've seen in some of the tech magazines, it claims to eliminate ignition noise from passing cars and CB radio interference. I'll be right back I'd better degauss the crt for the best picture possible.
Oh well that was then and this is now. Larry Melton still stuck in the past.
[IMG] |
