Old 01-19-2007, 08:49 AM
gary k. gary k. is offline
Philco round screen - CL
Hi -
Saw this on Craigslist. Very close to my house but in pretty rough shape.
http://minneapolis.craigslist.org/ele/264758200.html
Old 01-19-2007, 09:14 AM
matt_s78mn's Avatar
matt_s78mn matt_s78mn is offline
Originally Posted by gary k.
Hi -
Ooh, Mpls isn't that far for me I might give this one a try.
Old 01-20-2007, 02:00 PM
matt_s78mn's Avatar
...This makes color roundie #2 for me :)
Ok, I went to pick up the Philco early this morning. The cabinet is in really rough shape, it's going to need to be re-veneered. It has spent the last couple decades in a basement, but has been moved around carelessly a few times.
I followed all the initial start up procedures, and was able to get a picture, It shouldn't be too hard to get it working well again though. The CRT is a 21FJP22 and this will be my first attempt at cataract removal, so i'll probably be asking some questions when I get around to doing that.
I've attached some pics for you all to enjoy
...have a great day everyone!
Old 01-20-2007, 02:17 PM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
I think that is a CTC-15 clone. The only lytics are in the power supply, and I believe a few in the vertical. The reset Are mylar film, and rarely ever fail.
Looks like the green gun is weak, and you are missing most of your Y (video) signal. If your lucky and the CRT still has good emission, all you may have to do is replace the small amount of lytics, some tubes, perform greyscale and convergence.
After you change out the caps and tubes and get it running well, make sure to check the Ho cathode current. Anything more than 210ma and you run the risk of cooking you flyback.
You may want to consider This if your CRT is weak. just make sure you instruct the seller how to properly pack it.
Jordan
Old 01-21-2007, 10:20 AM
matt_s78mn's Avatar
Thanks for the info Jordan. I did some more tweaking and changed out a couple tubes and was able to improve it quite a bit. The crt has good emission on all 3 so I'll let someone else go after that ebay auction.
Yea you're right, it's a clone. One thing seems odd though, there isn't a single philco tube in the entire chassis. Most of them are magnavox, the rest are rca, ge, and raytheon. I would assume that means this set has pretty high hours.
Are the convergence adjustments going to be a nightmare on this set like they are on my ctc-31?
Here's some more pics of my progress:
Old 01-21-2007, 12:00 PM
Pretty good picture so far if you ask me...Yeah, convergence is a tad off, but...
Old 01-21-2007, 01:36 PM
jpdylon's Avatar
did you have the set hooked up to rabbit ears, or cable?
The second pic looks like you have video smear. My CTC-16 has that problem too. Adjust the AGC a bit and maybe it will clear up. Are your tuner and IF tubes all good?
Jordan
Old 01-21-2007, 05:19 PM
matt_s78mn's Avatar
It's hooked up to cable. Yea, the tuner and IF tubes all test good. I suppose it could be smear so I'll have to check the agc control.
...thanks
Old 01-21-2007, 06:00 PM
oldtvman's Avatar
oldtvman oldtvman is offline
Larry Melton (oldtvman)
Stick with the easy stuff first
Anytime you have ringing or picture smear, the first thing to do is resolder all the grounds on the IF/color board and also on the tuner coax cables. Make sure all factory shields on pc boards and any tube shields have been replaced. Sometimes just fixing the easy problems will cure syptoms you think are much more severe.
[IMG]
Old 01-21-2007, 07:41 PM
Old 01-22-2007, 09:20 AM
matt_s78mn's Avatar
Originally Posted by andy
I have the same set in a different cabinet and it also has similar video smear. Even after an IF alignment, it's about the same. It might just be the way that set is (maybe due to a Philco design change from the RCA chassis). Let me know if you find a solution.
Can you post a pic of your set?
Old 01-25-2007, 12:39 PM
Old 01-25-2007, 01:30 PM
Adam's Avatar
Adam Adam is offline
Here's a picture of the combo version of that set.
Old 01-21-2007, 08:46 PM
Definitely worth trying grounds in the video section - perhaps an open somewhere around the luminance delay line or its load resistor.
Old 01-22-2007, 08:51 AM
veg-o-matic's Avatar
veg-o-matic veg-o-matic is offline
Huh?
What does that say under Philco on the control panel?
Nice set! I really love that Danish Modern style.
Good luck with the convergence. I hate doing that.
veg
