Old 03-09-2007, 12:22 PM
everstan everstan is offline
AK Member
1951 19" Zenith Porthole 1951 24H21 sound issue
Recent full recap, tubes etc. and slowly pulling it out of it's slumber...
I am now getting a decent picture but I have a nasty background static noise although I can hear everything broadcasted clearly.
I have tried every adjustment on that tv there is and have only been able to moderate it to some extent.
I am using only rabbit ears. There is no affect whatsoever to anything that comes on the screen...just constant slightly irratic buzz. I replaced some resistors with metal film and now I am replacing those with carbon thinking maybe they are causing interference.
I don't think it is the audio output amp generating the static because when inject 1K sound just after all the video stages I get a nice clear signal.
I keep thinking either low or high voltage is somehow getting affecting the sound but I am not competent enough to first eliminate a video getting in.
I am new to this and trying to figure out how to inject a signal though the video stages right after the tuner or audio output. Can you lead me down the best pathways?
As always,
Thanks
Stan
