Unusual TV
Hello.
I have posted a couple of times about this set, but I didn't have good pix until now. This is a Mitchell set, and I am having a difficult time trying to find any information about it. I obtained a new pix tube (21MP4) from El Predicta on Saturday, but am at a loss on the rest of the set. A dligent search (3 years) has not led to anything made by Mitchell except for a few radios. I hope that someone has an old Sam's or Riders in a dusty corner, or information of any kind for this otherwise unknown set. Here are some pix, hope they help. -Chris |
Sometimes SAMS indexes by the chassis number, not the model number. Is there a chassis number stamped (or inked) on the back of the chassis anywhere?
That record player/radio looks curiously like similar vintage Zenith. I don't see the typical "cobra arm" tone arm though. Not that this observation helps in finding info on this set. I have heard of Mitchell as far as radios and WWII bombers but I've never seen a TV.
Chris:
I have the Riders info for your set. PM me with your address and I will copy it and send it off to you tomorrow. Steve |
Rider's Info
Hello.
The Rider's information seems to be rather accureate as far a tube layout/ etc. I haven't really dug into the TV, but will soon. -Chris |
Recapping Progress
Recapped the TV Section last night, plan to do the radio/phono tonight. I bought a good selection of HV caps, and it sure seems to be helpful. Thanks for the Rider's manual! The Schematic is spot-on perfect, although the radio section isn't there, but it should be fairly simple, condsidering it is just an AM/Phono.
High Voltage Problem
Hello.
I powered up the Mitchell set last night after recapping all except for (2) .1uf 600V caps that I couldn't source. The trouble now is that I can't get any High voltage or raster. I do hear the flyback whining, and it may be my misunderstanding, but I thought that the sound of a flyback and good tubes would indicate High voltage present. I unfourtunately do not have a HV probe, and can't clearly think of a way to measure the voltage without one. Any assistance would be appreciated. Thank You!
Hey all.
I just wanted to update on this set. Last evening, I spent several hours chasing the horizontal section after finally finding and ordering a 3900 pF 400V cap. That didn't fix it directly, but required replacing a resistor that was 28% out of spec. Seems a liitle more than a silver band should allow lol. Anyway, got that changed and messed with the hor. frequency control and got a beautiful horizontal sync. Vertical is another story. The raster fills the screen, with a compressed pic in the top 3 inches with various tracings in the rest of the screen. I suspect more bad resistors, but it was 12:15 PM, and I had to work at 6 AM. I'll do more tonight if I have time. -Chris |
Mallory makes the .1uF 600+V caps you are seeking. Antique Electronic Supply has 'em @ http://www.tubesandmore.com
Let me live in the house beside the road and be a friend to man. |
Thanks,
I did have some new .1 uF 400V caps, and after I really looked at the circuitry and schematics last night, I believe they will work alright. |
If you have a pair of 0.05uF at 600V caps, use them in parallel to make 0.1 at 600V cap.
As for the wrong horiz frequency, you probably are locking at some simple fraction of the correct frequency. Say 3/4 or 4/3, or such. |
