Old 10-06-2008, 11:44 AM
Steve D.'s Avatar
Steve D. Steve D. is offline
COL-R-TEL on ebay
1950s COL-R-TEL Color Wheel Converter Mechanical TV NR - eBay (item 190257288438 end time Oct-12-08 14:01:21 PDT)
http://cgi.ebay.com/1950s-COL-R-TEL-...d=p3286.c0.m14
-Steve D.
Old 10-06-2008, 12:46 PM
intotubes's Avatar
intotubes intotubes is offline
AK Member
http://www.earlytelevision.org/col-r-tel.html
An explanation of how it works.
Unfortunately this one is missing to many parts to ever hope to work unless you build your own circuit to run it.
Main system:
slightly mod'd Dynaco PAS 3,
DIY SE 6BQ5 amp
Pioneer PL-518 TT
Altec Lansing Model 19 (upgraded w/902-8G)
Old 10-06-2008, 02:45 PM
Carmine's Avatar
Carmine Carmine is offline
...enjoys spaghetti.
And it's not digital.
From Captain Video, 1/4/2007
Old 10-27-2008, 07:42 PM
cbenham's Avatar
cbenham cbenham is offline
I thought all analog TVs were "digital convertor ready" #;^)
Old 10-06-2008, 11:45 PM
That occurred to me as well. Who would want this adapter without the interface unit between it and the TV?
I also question the statement that this converter made "reasonably good color pictures" when used with a very small b&w TV. I cannot see how a color converter such as this, using a color wheel spun by an electric motor, could produce color images anywhere nearly as good as those from a modern color TV receiver. I would think color pictures produced by the Col-R-Tel system would be mediocre at best.
Old 10-07-2008, 11:39 AM
I have seen one demonstrated at an ETF convention and the picture was surprisingly good.
Listen to the video on the ETF Col-R-Tel page and you will get a nice description of how it works. Quite ingenious. The interface box picks off the color information from the signal and then makes the TV show the red information when the red part of the wheel is in front of the CRT, and so on. So you are viewing "real" color TV using a black and white receiver plus this gizmo.
Even though it's missing the electronics, this could make a cool display item for someone interested in early color.
Phil Nelson
Old 10-06-2008, 03:48 PM
stromberg6's Avatar
Good one Carmine!!!
Kevin
stromberg6
Old 10-06-2008, 11:49 PM
Old 10-07-2008, 12:04 PM
kx250rider's Avatar
REAL TVs have TUBES!
Great display piece, and I bet it goes in the $1K range... But for every pair of Col-R-Tel chassis sets I've seen, there were about 5 wheels.
Charles
Old 10-26-2008, 09:35 PM
mbates14 mbates14 is offline
i see chris nailed that sucker. i knew he would ;-)
Old 10-27-2008, 04:08 AM
cbenham's Avatar
It was as the seller described, had been sitting in a very hot attic for many years, plastic windows warped beyond usable, some of the wheel filters warped too.
The good news is I've recently learned the filters can be flattened out again by laying the wheel on a table and carefully placing heavy books on top covering all the warped segments...for at least a month. [!!!]
The motor bearings were very dry as was the wheel bearing which took a while to work loose from the 53 year old gummed up lubriplate in it. A good treatment with Hammond Organ Generator [turbine] Oil and it will spin easily again.
The wheel itself is complete and I can probably make it work again like the one in my Avatar. Don't have an electronic chassis for it, but I've always wanted to build something like that from scratch, maybe using the Colordaptor plans from R-E January and February, 1956.
Film@Eleven
Old 10-27-2008, 06:40 AM
ChuckA's Avatar
ChuckA ChuckA is offline
Cliff,
I think I have a parts chassis around here someplace, if you're interested I'll look around for it tonight.
I have my wheel working and one is enough for me.
Chuck
www.myvintagetv.com
Learn from the mistakes of others -
You can't live long enough to make them all yourself.
Old 10-27-2008, 07:59 AM
JB5pro JB5pro is offline
That's incredible!
I think it would be wild to watch that thing work. That image of Superman in that avatar looks beautiful. I saw another photo somewhere on here of one operating and the picture looked fabulous. It would be very funny to have to turn up the sound to over power the sound of the motor and whirling wheel. I wonder how much that set-up was when new? I would guess it was about half the price of a standard color table model. Maybe $350.00?
Old 10-27-2008, 05:37 PM
cbenham's Avatar
Originally Posted by ChuckA View Post
Cliff,
I think I have a parts chassis around here someplace, if you're interested I'll look around for it tonight. I have my wheel working and one is enough for me.
Chuck
I'm very interested! I hope it turns up.
Cliff
Old 10-27-2008, 09:32 AM
Im thinking the CRT he is using in that avatar is the one he cam and picked up from me, from a scrapped GE. good CRT
As far as warped plastic, the best for that is to "heat press" it. get some strong humidity/steam up the wheel to a high temperature and press it. and leave it pressed as the wheel cools down for the longest time period. I had to do this for my peter yatzcer wheel. hehe...
P.S. the wheel operates at a very low RPM, its hardly audiable. unless its scratching against something of course, or if the motor is shot.
