Old 11-18-2009, 04:39 AM
AUdubon5425's Avatar
Source for Tonearm Leads?
I didn't get any response in the tech forum, so I hope I have some luck here.
I'm looking for a source for tonearm leads. I have two stereos with shorting tonearm wires; the local sources are gone and searching the internet all I can find are audiophile-grade high-dollar sets.
Someone must still be selling these.
Old 11-18-2009, 11:23 AM
Wires from a junk USB mouse cord?
Old 11-18-2009, 11:53 AM
leadlike's Avatar
leadlike leadlike is offline
Without going too audiophile, I'd think any thin (27g?) wire would do. I just saw a DIY arm that used bare enameled magnet wire for leads. For connectors, grab them out of an old d-sub connector and solder them on.
Old 11-18-2009, 04:20 PM
Ohighway's Avatar
Ohighway Ohighway is offline
There ya' go...
Console, chairside and table top radios. Test equipment , tubes, and a couple TV's. Oh, and tube/SS audio equipment.... lots and lots of audio equipment.....
Old 11-18-2009, 01:48 PM
Reece's Avatar
Reece Reece is offline
This outfit has several selections.
http://www.garage-a-records.com./products.php?cat=131
Some have crushed a 7 or 9 pin minature socket to get the terminals out: adaptable to phono cartridges.
The idea above about stripping wire out of flexible mouse cables, or flexible non-coiled phone cables is sound advice. Superflexibility is what you're looking for.
Reece
Old 11-18-2009, 04:14 PM
7"estatdef 7"estatdef is offline
Might try dollar store headset leads.
Terry
Old 11-19-2009, 07:56 AM
Reece's Avatar
If you use recycled wire from any of those sources above you want to be sure to twist the two wires together along their entire length as that helps cancel hum. I would carry them through the arm and below deck with a bit of slack and to a terminal strip mounted close by, then solder on shielded cable from that point. Your turntable may already be set up that way.
If it's a stereo cartridge twist the lefts and the rights separately.
Reece
Old 11-19-2009, 11:37 PM
Thanks for the ideas guys. I think I'm going to try telephone wire, since I have some on hand.
