Old 05-06-2010, 09:42 PM
Early Sylvania Roundie on the 'Bay
Oh my! This is not something that you see everyday!
http://cgi.ebay.com/1957-SYLVANIA-CO...item27b192419c
I am not affiliated with this auction,
Old 05-06-2010, 09:54 PM
ctc17 ctc17 is offline
Amazing! What are those red sticks on the back of the crt?
Old 05-06-2010, 10:25 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
That's really close to where I grew up.
Too bad the 21AXP22 is dead.
John
Old 05-06-2010, 10:26 PM
jeyurkon's Avatar
Isn't the corotron the one that's impossible to find and difficult to sub?
John
Old 05-06-2010, 10:18 PM
There are only two of those known to exist. This one and the "Saratoga" 31C606MU IIRC, which is a floor model. I owned that one for a short time. I had to sell it to a friend because of a major home repair that I had no money for. Now I wish I had the set back but oh well, it's got a great home. The red sticks are the purity magnets. The chassis is of a Sylvania design with circuits licensed through RCA. The HV section is almost identical to a CTC2B but uses a corotron tube for regulation. VERY interesting set to play with. I'm bidding but I doubt seriously that I'll win.
Old 05-06-2010, 10:24 PM
David Roper's Avatar
console lover
Mark, do you mean the set in the auction is one of the two which were previously known?
David, you are correct! These came from a Sylvania employee that had them forever, he lived in Pa. I think he's passed now IIRC. The set I got made it's way to Detroit and then to my house and now, not very far away.
John, It is almost if not impossible to find one. The good news is that it can be modified to use a 6BK4 like an RCA.
Old 05-07-2010, 12:23 PM
Did you win it??
I guess if your going to get the crt rebuilt you got a few more weeks to get it in to Hawkeye.
Old 05-07-2010, 12:45 PM
jeyurkon's Avatar
Guess it was rare! I didn't expect it would go that high. And no, I didn't bid.
John
Old 05-07-2010, 01:15 PM
Old 05-07-2010, 01:25 PM
Steve McVoy's Avatar
We have a 21C609 at the museum, which is a CTC4 clone. It is in Sams 352, while the 31C606 is in 391. I guess they sold the 21C for a few months until they could get their own design to the market. Strange that it uses a gas regulator tube when the shunt regulator had been in use in almost all sets for 2-3 years.
Old 05-07-2010, 03:21 PM
That didn't take long.
Who can explain those controls above the screen? I'm guessing that's a channel indicator in the center, but can't make out the rest.
Those red stick magnets kill me. Looks like something I would come up with. Let's see, all I need is a pack of soda straws, some little dime store magnets, and a roll of duct tape
Phil Nelson
Old 05-07-2010, 06:25 PM
ohohyodafarted's Avatar
Bob Galanter
I think it probably used a coretron because of the simplicity. Just clamp it to ground and connect the HV lead and you're in business. May have even been more cost effective (no tube socket, no high megohm voltage divider resistors etc) This chassis also used the same flyback that is in the RCA 21CT55, relabeled as a Sylvania part number. The only reason I know they are the same, is because I had to do a lot of work on my CT55 HV section and I would recongize that flyback anywhere. I have not tested the coretorn in my Sylvania yet, but I would bet it is crap like most of them are.
ME http://AntiqueTvGuy.com
Old 05-08-2010, 10:39 PM
JB5pro JB5pro is offline
About a year or two ago I met a man who said he has a metal cone color tube...
so I suspect it must be a 21AX. He has a radio repair shop close to Fort Lauderdale. He seemed to be the sort that would be very difficult to deal with but I have been wrong many times before. So, I suspect others wil have one but I would try to find him again if anybody would like me to do so.
Old 05-07-2010, 04:30 PM
No, I didn't win, I WISH! Since I already owned one of them I should have just kept it. I thought his BIN was stupid, that set would have gone higher in bids. As far as design, that set used everything that was already outdated like the corotron tube, a lot of the circuits were throwbacks to RCA's of previous years. They just incorporated them into their own design. The slide "ratchet" controls on top are for changing the channel, at least the right one is, the other one is the power switch. It sounds like a regular ratchet when you change channels, it's pretty neat. The color, tint, contrast and brightness are located below the screen. The controls are barely visible even when you are in front of the set. The purity assembly is of their own unique design, hence the weird looking "straws" for the magnets, you twist them to make an adjustment. Let me tell you that I would have STOLEN that at $1,700 if I had it to spare. It is worth much more. You will find ten CT-100s with good CRTs before another one of these shows up. SOMEONE did steal it at that price, I hope they are a member here.
