Old 10-25-2010, 11:51 AM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
I love my roundie but it sure is high maintenance.
I recently replaced an electrolytic cap that went bad and got the old Zenith 25MC33 working again. Just the other day the vertical hold went way off and when I adjusted it back in the height had pulled in from the top and bottom about a quarter of the screen. I have noticed a blue glow in the vertical output tube. Can a gassy tube cause this? I turned the set off and on again and the picture returned to normal for a while. Also, it now occasionally comes on like the brightness control is way up, not all the way or with retrace lines. If I turn it off for a minute and then on again it is normal. It still has a lot of original Zenith tubes still in it.
Old 10-25-2010, 01:24 PM
kx250rider's Avatar
REAL TVs have TUBES!
A couple of thoughts... It sounds like a complete re-cap might save you a lot of headaches later. At least all the rest of the electrolytics, and any of the brown shiny Sprague paper caps. As far as the blue glow, that can be caused by air leaking into the tube, or too much current load across the tube (more likely the latter). That Zenith is a good chassis, but it's still 45 years old, and that technology, while the best at the time, did require a fair amount of babying.
Charles
Old 10-25-2010, 11:45 PM
miniman82's Avatar
First Light: 1952-2011
A set I'm working on now has some seriously drifted resistors that pull into spec once the set has been in operation for a while. Might be worth poking around with some cold spray on your set, to see if maybe the same thing is happening to you? Also second the recap.
Evolution...
Old 10-26-2010, 12:41 AM
Old 10-26-2010, 01:18 AM
miniman82's Avatar
Totally agree, though my CTC-9 displayed a fine picture before I even replaced the 'lytics. Some sets just have lower quality parts in them, that's all.
Evolution...
Old 10-26-2010, 09:01 AM
oldtvman's Avatar
oldtvman oldtvman is offline
Larry Melton (oldtvman)
That's what kept tv service guys busy
Back in the day those were the kind of problems that kept shops busy. Color sets of the time required more attention than the sets of today. It was a great time.
[IMG]
Old 10-26-2010, 10:41 AM
If it ran 45 years with original electrolytics and mostly original tubes, I'd call that pretty low maintenance.
I'd replace the electrolytics and then see where you stand. They are so frequently bad that I don't bother trying to diagnose problems until they have been replaced.
Just my $0.02.
Phil Nelson
Old 10-26-2010, 11:10 AM
compucat's Avatar
1949 Motorola 9VT1
Phil Nelson
It has spent probably at least a decade out of service. It was lonely and unloved when I bought it from Harry Poster about four years ago. Since restoring it in 2007 I have tried not to put too many hours on it although I do use it frequently for no more than about an hour or two at a time. My black and white tube TVs and my tube radios I run the heck out of them.
Old 10-26-2010, 11:54 AM
I view the "maroon drops" as a sort of in-between category. My RCA roundies still have a lot of originals, but I have replaced some, too. I would replace the electrolytics and then approach the maroon guys on a case-by-case basis. A more risk-averse person would shotgun all of 'em, I suppose.
The consequences of losing an electrolytic can be dire, depending on which one goes poof. With those, I show no mercy.
Phil
Old 10-26-2010, 04:29 PM
oldtvman's Avatar
the exception not the rule
Just my $0.02.
Phil Nelson
Phil, I remember ctc series eating flybacks in the day, others had different problems, the Admirals also ate flybacks, but most problems boiled to dirty controls bad switches dirty tuners all of which could cause weird problems sometimes if you weren't familiar with servicing that peticular brand. Most people would set there and watch color pictures that were severely out of adjustment probably because they were never instructed how to set the controls up properly.
[IMG]
Old 10-26-2010, 11:07 AM
compucat's Avatar
1949 Motorola 9VT1
I agree that it was a great time. My tube type black and white sets are generally more trouble free than the tube color set simply because of the tube and parts count. Of the non electrolytic caps, which ones are in the league of paper caps and should be replaced? I know the black beauties and any bumblebee caps must go. The Zenith has many that look like orange drops but they are either brown of maroon colored. Are these to be replaced too? I hope not as there are a million of them.
Old 10-28-2010, 10:06 PM
ctc17 ctc17 is offline
Guess what....I got a 25MC32! Good crt but the damper red plates and no HV.
I also have a 25MC36 rectangy and it has been super reliable.
I can t wait to get this thing running. Its such a cool looking set.
Old 10-29-2010, 09:47 AM
holmesuser01's Avatar
I got my first roundie, a CTC-10C, in 1974. So, it was 14 years old. CRT was broken, and a few tubes missing. I also got a CTC-11 chassis from the same guy. Also, missing a few tubes.
Installed a used CRT, an FBP, and tubes, and it came to life. It ran good, not great. In 1984, I installed a brand new FBP CRT. I had no idea that there was a difference in the FBP and the CYP that it came with. I used the set daily for almost 10 years.
In 1995, I replaced several OEM tubes, and some of the electrolytics, and it plays on.
I imagine that it is too late to find a 21CYP22 tube for this set, so it runs OK with the FBP and no modifications.
I dont run it much anymore, but, I do run it now and then. It's connected to the satellite, and the picture is still good with good linearity and color. The tuner needs some attention, so when I pull the chassis, I'll check it over.
It's the only CTC-10 that I have ever worked on. It seems to be built better than the later stuff like the 12's and on up.
I've worked on one Zenith roundie. It had something going on that would kill the damper after a few hours of playing. I was just beginning to work on tube stuff at the time, and it baffled me. I had it sitting in the showroom in my shop for years.
I know people that had roundies back in the day, and it was a normal occurrence to see the TV repair shop truck in their driveway. That said, I have an aunt that had a RCA CTC-16X that ran from 1964 to 1978 and never had the back removed for any reason. She replaced it because the colors weren't perfect anymore, and she wanted a new Magnavox in a pretty cabinet. She had the Maggie serviced alot, that I remember.
Those were the days.
Bruce
Old 10-29-2010, 01:39 PM
Brief detour into RCA-ville. My CTC-11 tuners were helped by opening them up and cleaning contacts with Q-tips dipped in DeOxit. Spraying cleaner all over the place is a Bad Idea. Don't use anything abrasive on the contacts.
Phil Nelson
Old 10-29-2010, 03:49 PM
Phil Nelson
A slightly more detour into RCA land:
I promise I will not spray anything into my RCA tuner. I cleaned it about 25 years ago, and it is time to do it again.
And now, back to our regularly scheduled program, in progress.
