Old 05-29-2011, 01:13 PM
diamondsouled's Avatar
diamondsouled diamondsouled is offline
Philco 53A s console radio ;^)
Picked up a very nice example of a 1940-1 ? made in Canada Philco 53A s radio at a garage sale yesterday. Don't see many radios this era with the cabinets in such good condition. At least ones that are for garage sale prices . Expected to see a field coil speaker but there is actually a rather large 12" speaker that looks like a Jensen. All the tubes are present but I haven't been able to track down a schematic yet.
Will need some TLC for sure.
Here's the tube compliment from left to right:
6J8E, 78, 6J5, 617FG, 6C5, 2 - 48s.
Yesterday was a good day. Actually picked up some nice vinyl for free as well.
Cheers
Lar
Altec Valencias ESS AMT1A Monitors Revox B795 TT Uher Royal Deluxe RTR VAS Cit Sound Mono Blocks HK Cit I II III Acrosound UL2 Acrosound S1001 ARC SP3
Old 05-29-2011, 03:17 PM
That out board speaker transformer makes me think that this set originally had a speaker with the transformer mounted on it, and when that died they put the present speaker in and convienently mounted the new transformer for it next to the chassis.
That is my impression.
Old 05-29-2011, 03:20 PM
I was thinking the same thing
Old 05-29-2011, 03:32 PM
7"estatdef 7"estatdef is offline
Very odd tube lineup 48's are battery type tubes.
Terry
Old 05-29-2011, 06:55 PM
Could be someone did a switcherooney on the tubes. When I track down a schematic I'll find out for sure.
Old 05-30-2011, 06:54 AM
Reece's Avatar
Reece Reece is offline
Not uncommon for a vendor to just stick whatever tubes in empty sockets to sell a set.
Ditto on the posts above about the speaker probably being a replacement. The cord hanging down with the plug on the end would have gone to the original speaker that had a field coil. Wonder how they tackled the lack of the field coil in the circuit? Choke or big resistor under the chassis? Looks like only two primary wires going to the output transformer. Does that radio have push-pull output? If so should be three wires. Circuit may have been "modified."
Reece
Old 05-30-2011, 05:15 PM
It looks like the speaker replacement was done by someone who knew what they were doing. The wires to the transformer as well as the plug do look like a mouse chewed on them.
Will be nice to get a schematic to see what's up with the tube compliment, also to see what's been done with it to compensate for the missing field coil..
Lar
Old 05-31-2011, 02:23 PM
Here is a good source of free schematics if you are having troubles finding schematics www.nostalgiaair.org/.
Old 05-31-2011, 08:13 PM
Justradios doesn't have the schematic, yikes
Old 05-31-2011, 11:57 PM
Are you sure 53A is the model # ? I would have thought it would have the first two digit year follow by the model like 40-81 or 41-22 .
Old 06-01-2011, 07:15 AM
Reece's Avatar
Model 53 (no A) is around 1930, IIRC, nowhere near this radio. Did they use a different numbering system on Canadian sets?
Reece
Old 06-01-2011, 07:15 PM
According to the Philco Radio page:
"By June 1938, the radios produced in Canada began to look very different from USA Philcos. The company also adopted its own model numbering scheme, which results in confusion today among radio collectors, since many later Canadian Philcos used the same model numbers as older USA Philco sets."
http://www.philcoradio.com/world/canada.htm
The 53X in the picture is the same as mine.
Cheers
Lar
Old 06-07-2011, 05:09 PM
electroking's Avatar
a- v- karma member
Hello again,
Here is the closest I could come up with. I found a model 53 (not 53A) but the
tube complement for this one looks more similar. It is very unlikely that this radio
had anything other than a 80 as the rectifier. Will get back to you later.
Regards.
P.S. It would be useful to have a close-up view of the data plate, and
to determine whether the output stage is actually single-ended or
push-pull.
Old 08-11-2011, 08:09 PM
jjhobson jjhobson is offline
1942 Model 53X
I have this same model. It took awhile to find the year and model and I have yet to find even a ball-park value. Do either of you have any idea what they are worth today?
Old 06-01-2011, 09:37 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
I've been a Philco fanatic for many years. I know just about every Philco set there is. I have NEVER seen this set, nor anything close to it. Just wow.
I'd peg it as a 1942 model, given the cabinet style and glass, but I have no idea beyond that. We really need some more info here
