Old 07-02-2011, 11:55 AM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
RCA Victor7T174K TV
This is my latest acquisition. It is in a limed oak finish. The lacquer is shot and I plan to strip the remaining lacquer off and recoat. The veneer is in good shape with the excepton of a small chip in the top. i can live with that. I like this set for its compactness and very profound early TV style. Is is complete with all the knobs, none of which are broken (unbelievable). I found out from some research that this model is called the Kendall. It has a 17 inch screen and features four IF stages. I bet it will be quite a performer.
The set had previously been working but now there was no picture. Upon removing the back I discovered a brightener hanging off the 17QP4 glass picture tube, never a good sign. I put my crt tester on it and it started out on the red but slowly came up to green. I ran it at 7 volts for a few minutes and it went well into the green area. It seems to be a good tube after a little wake up with no shorts or anything. I'm not sure what the brightener was doing on there to begin with. I found one electrolytic in the voltage doubler that was getting warm so I disconnected it and temporarily clipped in a new cap. This time I got white noise from the speaker and nothing else. The neon bulb tester told me the horizontal stages and flyback are working. The high voltage measures only 8KV when the Sams says it should be 13.2KV. I know the power supply will have to be rebuilt since the selenium rectifiers and electrolytic cans are original. I have not looked under the chassis yet. The set is reported to have been recapped. There is only a small pile of wax at the bottom of the high voltage cage. Overall the chassis looks to be in good shape. There is no sign of 1950s yoke cover disease. I did notice that in addition to having a lighted tuning dial that there is a pilot light mounted at the center bottom where the legs are. I assume this is so you can tell the set is on if the doors are closed, very interesting feature. My question is this. is there supposed to be some kind of lens in front of the cabinet pilot light? I just have a small hole visible from the front of the cabinet. it almost looks like there might have been nothing there, especially seeing the way the lamp fits into the hole from the back. I am really looking forward to restoring and using this set.
It does lack one feature that most of my sets also lack and that I need to install fairly quickly. It is the WAF or Wife Acceptance Factor. It rarely comes pre-installed on any vintage set. Here are some photos of the set as I received it.
Old 07-02-2011, 12:18 PM
John Folsom's Avatar
I would think that cabinet (with doors closed) would have some measurable WAF. It is rather attractive. :-)
John Folsom
Old 07-02-2011, 12:25 PM
Oh, yeah, I think the WAF oughta be FINE once you get the cabinet spiffed up...That's a pretty set !
Old 07-02-2011, 01:03 PM
holmesuser01's Avatar
There was a push-in jewel that went on the front of the set for an indicator. I've seen them before, but dont have a clue as to where to get one today.
Old 07-02-2011, 01:15 PM
compucat's Avatar
1949 Motorola 9VT1
I thought there might have been something like that. I will find something to put in there. I don't expect it will be that difficult.
Old 07-02-2011, 01:17 PM
compucat's Avatar
1949 Motorola 9VT1
Right now I am testing some material to remove what is left of the existing varnish. I hope this is not going to be too troublesome. The only two sets I ever had refinished were done by professionals. i would like to try this one myself.
Old 07-03-2011, 07:26 PM
Glenz75's Avatar
Glenz75 Glenz75 is offline
NZ Vintage TV Collector
Great looking set! Good luck with the restoration.. Cheers
Visit my Vintage TV & Radio Page - http://nzvintagetvradio.blogspot.com/
My YouTube Link - http://www.youtube.com/user/glenz1975?feature=mhsn
Old 07-03-2011, 08:42 PM
Penthode's Avatar
Penthode Penthode is offline
I think it should have a pretty high WAF considering it is a nice looking set.
Not only that, it features the KCS66 chassis which is a greater performer. Besides having a an excellent S/N cascode tuner and keyed AGC, it features a full 4MHz video bandwidth, has intercarrier sound and a DC coupled video amplifier. (Does this sound like RCA salestalk?)
RCA went to the DC coupled video amplifier I believe with the 8T241 KCS28 chassis. It dropped DC coupling with the KCS47 and went back to it with the KCS66. DC coupling generally means improved low frequency phase response which means the picture quality on this set should be excellent.
It is a great find!
Old 07-04-2011, 12:41 AM
I think I have the metal table model version of this set.
Old 07-04-2011, 12:17 PM
compucat's Avatar
1949 Motorola 9VT1
The metal table model is the one shown on the cover of the Sams. It is quite stylish too.
Old 07-04-2011, 12:22 PM
compucat's Avatar
1949 Motorola 9VT1
Factory Installed Video Input Jack
I was looking over the Sams for this set and discovered that it has a video jack connected directly to the cathode of the video output tube. I did notice on the back that there is an extra RCA jack on the chassis. It is not labeled unlike the one for the phonograph input. I just assumed it was a second audio input until I looked at the Sams. Was this for test or setup purposes? I don't imagine there was anything for the customer to connect to this in 1952. I will probably use this input to do the setup after I get the set going again.
Old 07-04-2011, 12:43 AM
So, basically this set has "DC preservation" and doesn't need restoration because it never took away the DC component?
Old 07-04-2011, 06:08 PM
I just checked and mine is a model 17-T-200, and it also has two RCA jacks on the back.
My set has been low on my restoration list, but now that I know that it has a video input I'm rethinking my prioritys. I don't have the schematic (if your sam's covers my model you could make me very happy by sending a copy to me) so I don't know if one could connect a DVD player, VCR, etc. to it directly, but even if will not work directly I bet a OP amp circuit could be built and installed under chassis to make it work (I sort of hope for the latter as I'd like to try my hand at creating said OP amp circuit).
Good luck on your restoraton.
PS: I think you have got a cooler cabinet on your set, but I'm still glad to have the table model due to my space limitations.
Old 07-04-2011, 07:02 PM
compucat's Avatar
1949 Motorola 9VT1
The Sams I have does not cover your model number but it does mention chassis numbers KCS66C and KCS66D. If this is your chassis let me know. I have the Sams as a pdf file and will be happy to send you a copy.
As far as using the video jack for a DVD player, you would also need another audio input. The supplied phono jack only works when the selector is in the phono position thus turning off the TV picture circuits including the CRT filament and sweep stages.
Your set looks great. Is the front of your set metal as well? I know some metal cased sets have plastic front panels and CRT bezels. I notice the back on yours has a moulded step to it. The console set just has a flat back. I found an advertisement for these sets.
Old 07-06-2011, 10:48 PM
If the jack is connected to the cathode, wouldn't that be an output, rather than a video in? Considering I'm not looking at the schematic it's hard to say for sure.
