Arvin 4080T 8" Table Set
I found this lonely little set at the local thrift store yesterday afternoon. It's not beat up too bad, but unfortunately it's missing its back cover, along with the on/volume and fine-tuning knobs. Also the center of the channel change knob has what appears to be paint splatter all over it, very strange
![]() The connector on the crt is loose, but the filament does light. I'm not even sure if an 8AP4 can be tested for emission on my B&K 466? I guess as it stands it's a nice parts set. Possibly someone has the missing parts? or even needs a better cabinet for theirs. I'm open to all suggestions. |
Cool, I'd like to find one of those at a Thrift Store!
The CRT should test on your 466, same settings as every other 40's tube, 10BP4 12LP4 etc. Someone surely has a back, there are so many of these all beat to heck, this one looks restorable. |
As far as I know an 8AP4 has no G2
Curiosity got the better of me, so I had to take a little peek under the chassis. Overall pretty clean, and looks like it should be easy to recap. I found the SAMS folder over on ETF. Boy it's hard to resist working on the latest and greatest treasure.
Great score. A compact set with lots of eye appeal.
Looks like the tuner uses air variable capacitors, similar to the Pilot TV-37 or this one in my Capehart-Farnsworth 661-P: ![]() I'd be tempted to start recapping, too. Is that an unobtanium CRT? Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html |
![]() Hope your CRT turns out to be good! jr |
Hi Phil,
This tuner is a little different. Google shows one NIB 8AP4 sold on ebay this past summer, so apparently they're not unobtainium. On the other hand I'm not too sure they were used in many sets. This is the first 8" I've ever run across. I expect a dozen complete TV's will surface before a crt only. |
I can't remember which one it is for sure, maybe the Sonora? The Raytheons with the variable tuner use slugs. |
If not I have them and could look it up. |
It shows G2 as being connected to the 2nd anode, which would be the shell of the tube in this case. I don't know what to tell you at this point, perhaps just try and test it omitting the G2 adjustment and see if that works, or maybe you could connect the anode to pin 10? |
BTW, that looks like a very clean chassis, I would do everything possible to restore this set!
I'd recap the chassis enough to get the HV and sweep working and find out how good the crt is, looks like it has all of 10 or 12 paper caps! Check the getter on the CRT first though to make sure it hasn't gone white. Generally the smaller metal tubes don't seem to have leakage problems as much as their bigger siblings. |
