Ceramic Capacitor Aging and Restoration
I have no idea if this is useful, or if it applies to the vintage ceramic caps we encounter, but I found this description from Johanson Dielectrics of the aging process for ceramic capacitors:
I haven't tried this, don't know if it is typically necessary, nor do I know if it is practical to heat up a chassis up to 125 degrees and not destroy everything. My guess is that it likely isn't that far above the normal operating temperature, but baking geriatric circuity likely is not a good idea and you can't blame me if you turn a radio or TV into burnt toast. |
Gads don't do that! All plastic parts will suffer. That includes dials, rubber feet, dial cords, windows, pointers, and many electronic components. Most consumer grade components are rated for 85C or so, and you will destroy the capacitors at least. Any moving parts will have lubrication run out. And you can say goodbye to any labels. Most plastic cabinets soften at ordinary hot summer temperatures, and that is seldom above 40C.
I'll have the hot baked capacitors with gravy on the side.
My posting specifically referred to only the chassis, but it seems that the rest of the case wouldn't suffer from baking. You surely are aware that most components, such as caps, are typically rated up to temperatures higher than 135° Fahrenheit? Caps are usually good to 85° Celsius, which is 185° Fahrenheit. Carbon-film resistors are good up to 155° Celsius. One could conceive of using a heat gun upon only the ceramic caps, or doing it with NOS parts that had not yet been installed. So my comment wasn't totally outlandish, ignorant, or downright stupid as you made it out to be. I would not bake nitrocellulose, acetate or other low-softening point (or flammable!) plastics. The fellows over at Antique Radios routinely bake radios at 180° Fahrenheit to remove moisture and improve performance: Quote:
The interesting part of the technical note, and why I posted it, beyond the explanation of aging, was this: "After the soldering process, the capacitors have essentially been De-Aged." That's interesting to me and it explains why the performance improves after baking. Some repair shops would even soap up and hose down dirty chassis before working on them: Quote:
And as far as baking electronics with plastics, a common trick to rejuvenate video tapes is baking them at 135-140° Fahrenheit for about two hours. The sibling site even has a page about doing this in a toaster oven. I knew a fellow who made a tidy sum, from audiophiles and business migrating tapes, by doing such baking before the technique was widely known. |
I guess I misunderstood. I thought you wanted to heat things up to 125C but apparently you meant 125F. Sure, that's not too hot.
Mix ingredients, bake at 180° for two hours. Enjoy!
My supposition is that it is the temperature + duration is what that matters, and that the specific temperature is less critical. I don't know if it's a phase transition, which I doubt because the temperature is pretty low for changing a ceramic. Many reactions occur much slower at lower temperatures, but they do happen. I don't know; I'm not a materials scientist. I just thought it was interesting. But it is clear to me that baking radios at 180° F for a few hours not only won't hurt anything, but should improve performance and reliability. |
As the article mentions, you have to heat it above the curie point (about 125°C for the ceramic in question) for any crystalline structure changes to take place. In the direction you want anyway.
It's not the heat, it's the humidity.
![]() That's one mighty steep dropoff. A brief return to the Interwebs for more information. Now this presentation on "Drift (due to Moisture) in Multilayer Ceramic Capacitors" is interesting (PME is Precious Metal Electrodes and BME is Base Metal Electrodes, usually nickel, a shift in the nineties): Quote:
I think that pretty much sums it up: high humidity is bad for ceramic caps (we knew this as a general rule about electronics) and de-aging (a different phenomenon than water-induced changes) requires heating past the curie point (and the point at which the wires and plastic parts melt). Since soldering does de-age, one could potentially heat the caps with a soldering iron and get the same effect. (Except for the potential issue of thermal shock, but that appears to apply to surface-mounted devices, although I read about how it is best to not overheat the traditional leaded ceramic caps during soldering.) The earlier links I posted about baking make a lot more sense in that all of the water is driven out of the caps. |
