Old 05-28-2012, 09:31 AM
robertnjax robertnjax is offline
CT 100 Plastic Yoke Cover Problem
The plastic cover on the back of my CT 100 yoke is deteriorating and falling off. It doesn't look like anything is damaged as a result of this. The white plastic cover on the front of the yoke is OK. Is this a problem and is this plastic cover available ? Serial number # B8001677 Cabinet number 524 Thanks
Old 05-28-2012, 10:01 AM
Pete Deksnis's Avatar
15GP22 demo @ ETF 2007
Hi Robert, the last time we communicated was five years ago. I have added your cabinet serial number to the Living CT-100 list. You are correct, nothing damaged your yoke cover -- unless you consider time and temperature. If your set had been in a controlled environment for its 58 years, perhaps it would match the quality that the rest of your set seems to be, as viewed in your posted pictures. I know of only one pristine plastic cover that exists. BTW when the crumbling cover is removed it exposes live terminals around the perimeter of the yoke. Take care to keep clear when the set is under power.
Pete
Old 05-28-2012, 10:12 AM
Yr set is JUNK now, please crate it up IMMEDIATELY & send it to me for Disposal....I have a HUGE Sinkhole in my back yard that I'm tryin' to fill up, & the City don't want me tossin' Old Tires innit, JUST Ct-100s...(grin)
Old 05-28-2012, 11:13 AM
kx250rider's Avatar
REAL TVs have TUBES!
I would think that someone who makes repro knobs and bezels, could easily reproduce that cover. They're all shot, and so are the ones on the B&W sets. The one in my first CT-100 had turned completely to white powder, and that was in 1984! Very simple plastic casting, and if the pristine one that Pete knows of, is available either for loan or to have a draftsman make up a perfect sketch of it, I'd say that's something to do immediately if not sooner!
Charles
Old 05-28-2012, 11:53 AM
Hello Everyone,
Pete, thanks for registering my set.
Here is some front view pictures of the CT 100's I've kept it all original so far. I'll look into a plastic part maker.
May be cheaper to just push this defective set into the land fill......just joking
Old 05-28-2012, 12:06 PM
ohohyodafarted's Avatar
Bob Galanter
How to make your own replacement cover
On my web site I have a tutorial on how you can make your own replacement yoke covers using inexpensive sheet styrene obtainable from Walther's Model Train supply.
http://antiquetvguy.com/Web%20Pages/...okeCovers.html
Good Luck and you can contact me directly if you need further guidance in this project.
ME http://AntiqueTvGuy.com
Old 05-28-2012, 07:32 PM
OMIGAWD, That Set is GORGEOU-erm, the UGLIEST, TRASHIEST thing I ever seen...SEND IT TO ME Immediately, so yr family & friends won't be overcome by its EXTREME Butt-Fugliness !! How do you STAND to be in the same ROOM w/such an AWFUL Contraption ?!? Think of the poor, Innocent Chilluns 'n' Pets... (Well, hell, if I'm "Over-The-Top" enuff, someday, SOMEBODY might fall for it...Hope springs eternal...)
Old 05-28-2012, 08:04 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
Robert,
I had a pristine, spare, CT-100 yoke, w/a nice shining black cover, sitting on a closet shelf for years. Finally decided to replace the old yoke w/the deteriorating black cover with the spare. Within a year or so the spare had also had it's black cover go to powder. The set works fine. Bob's fix is probably the only way to solve the problem.
-Steve D.
Old 05-30-2012, 06:03 PM
Thanks for all the good advice.
Robert
Old 05-31-2012, 09:54 AM
FYI: Here's a quick and dirty shot of what I consider to be a pristine CT-100 yoke cover. Best shot I could get without moving heavy stuff, but -- if you can blow it up -- check for reflections of yoke and CRT cables bouncing off the shiny black cover.
Pete
Old 06-03-2012, 12:52 AM
peverett peverett is offline
Ohydrofarted has a very good article on his website. I have been making somewhat crude yoke covers using the same styrene plastic(They may be cride, but they do work). As I do not have access to a lathe(nor room to put one), I have been using hole cutters. This works, but the sizes you can get are limited. It is also harder to make perfect circles with the drill hanging, etc.
A couple of things-my yoke covers are for B&W sets and have centering rings. These have to be accounted for in making the portion of the yoke cover that is clamped to the CRT to hold the yoke straight. Luckily, in two of the cases, (an Admiral and RCA), spring clamps for holding these on the cover were still in the set. The issue is making sure the centering rings can still be adjusted on your new cover.
One of the yoke covers I re-built was made of two types of plastic, the celluloid that falls apart and a center section made of a later plastic that has held up fine for 50 years(the TV is an 1963 RCA). This made the centering ring issue easier as the rings were mounted on the good plastic.
Old 06-03-2012, 07:23 AM
tubesrule's Avatar
tubesrule tubesrule is offline
Pete,
If the pristine cover is available for reproduction, I could ask Ed (the guy who I had reproduce the VT71 and TRK12 masks and makes all the knobs and stuff) to reproduce them.
Any idea how many he would need to make and at what price? I know he is extremely busy but I'm sure he wouldn't mind adding more stuff to the list
Darryl
Converters for obsolete standards:
www.tech-retro.com/aurora-design/legacy.html
Old 06-05-2012, 09:46 PM
rcafan rcafan is offline
Is the yoke diameter the same as the ctc4.
Old 06-10-2012, 09:08 PM
Spoke with John Folsom earlier this evening and he brought up rcafan's post. John did confirm that his yoke cover fit both the CTC2 and CTC4 yokes.
Pete
Old 06-10-2012, 11:51 PM
Might be able to sell it to the larger CTC-4 owner base as well.
