Old 11-08-2012, 06:14 PM
panasonic travel tv 1 inch screen
does anyone know these little bw tv sets? just got one and appears it dont have horiz nor does it have crt heater. the hv it has but its 2kv so i dont know what it should be but it has that much. with the other little sets it was the horiz hold pot but not this one and im not sure where it gets the heater voltage from, im guessing from the flyback. if anyone knows these give me a shout.
Old 11-08-2012, 06:48 PM
crtfool's Avatar
crtfool crtfool is offline
What is the model number?
Old 11-08-2012, 06:58 PM
tr-1010p panasonic
Old 11-08-2012, 07:05 PM
crtfool's Avatar
OK - now I know what to tell you. This is the worst model of the Travelvision line - it is going to need a complete recap of all the electrolytic capacitors. You also need to see how bad they leaked, and how much damage has been done to the very fragile traces on the circuit boards. Also, the ribbon cable portion of the circuit boards are very fragile, and tear very easily.
Good luck!
Old 11-08-2012, 07:24 PM
Good luck!
ok i found out about the ribbon but ill fix that but the caps are the culprit? some of the cap leads have some green on them like it was stored in a damp place. caps will cure this junk because it dont have the crt heater as well.
Old 11-08-2012, 07:35 PM
are there any issues with any of the ICS that you know of ?
Old 11-08-2012, 07:55 PM
ctc17 ctc17 is offline
Why dont you run over that with the lawnmower and ill send you a watchman. I have a few floating around here somewhere with spots teams logos printed on them.
What am I ever going to do with all this junk!
You can get a BT modulator going on a good homemade antenna and take the micro tv outside when you have your ciggyclogger.
I get 500' of coverage easy with my modulator and antenna on a watchman.
Old 11-08-2012, 08:03 PM
crtfool's Avatar
ctc17 - I like junk, you have anything that I might be interested in the way of these small CRT or LCD TV sets? What model Watchman TVs do you have?
Old 11-08-2012, 08:51 PM
Someone at the swap meet had a big box of them, I felt sorry for them and got the whole box. Its around here somewhere, I have no idea where.
The small stuff just isnt real practical sense the analog shutdown. Ohh and my eyes suck so that really makes them pointless.
Ill look around here when I get some time and Ill give timmy first shot sense he seems to like tvs that require B&D to get working.
I do like and have several restored 60s vintage small metal sony sets. Those are super cool.
Old 11-10-2012, 08:00 AM
well when i get tired of trying to get it going ill try the lawnmower,lol. and what you should do with all your junk is what dont work you should get going including these little tvs,b@w or color much harder then the tube sets but im sure you can get them going. this 1 inch tv is weird i have never seen a crt as small as this but it would be funning to get a pic on it. and besides if i get it going i just have to clip a 75-300 trans to it and laugh at it while im watching spongebob, lol,lol. well it has clear sound so thats not a problem so im thinking if it has sound then hopefully the video is there for when i get the crt to light or whatever the problem is. and btw i put a new video tube in the maggie but it didnt really brighten it up so maybe ill take it apart and sell off the parts , ahhh, such as life with tvs. and what you should do with stuff or junk is send it to someone that will take care of it or use it.
Old 11-10-2012, 09:05 PM
Naw dont give up on or part the maggie. One at a time timmy. Fix the one inch one then take a break then work on the maggi.
Its the challenge of fixing the crap more than anything, im like that too. I only have fun disposing of these modern plastic sets I still find 1-2 of each week.
I would love to see some pictures of the inside of the set you are working on.
Anybody know if the color version, CT-101, had similar problems ? For it to be a "Flagship" type of product, they sure were cussedly "Cheap"...You'd THINK they woulda spent more than 15 cents on the cabinet...Seems like I spent $350 in '84 on mine...Had the local hdware store order it up special...Got LOTS of Fisheyes, too..."You want THAT ?!?..For the same money, I can get you a 27" REAL TV.."
Old 11-08-2012, 08:00 PM
crtfool's Avatar
Sandy - the CT-101 is very electronically sound. The plastic cabinet is it's worst enemy, as well as people leaving batteries inside to corrode, out-gas, and leak.
Old 11-08-2012, 08:12 PM
Kewl ! Don't think I've EVER left the batteries in mine more than a night or 2...It sure was a HANDY little trick to set yr Camcorder up with...No more purple or green faces...And it AMAZED people, too...I have a candid shot of a buddy of mine holding & watching it, he has this look of utter amazement on his face..
crtfool's Avatar
The IC chips generally do not fail, but they could be damaged from leaking electrolyte from the caps - if they are not corroded, then they should be OK. Green corrosion on the capacitor leads is 1 sign that the caps are defective. A complete recap should bring the TV back to life, if all the circuit board traces are not compromised - if they are, then they need to be repaired. An ESR meter would be very helpful if you do not intend to replace any capacitor that does not look physically damaged - they most likely will be electrically damaged.
